Old 09-03-2015, 07:20 PM   #1
TURBS's Avatar
Sabre Bedroom slide adjustment.
Anybody ever have to adjust the bedroom slide in there sabre?
mine has sagged just a touch and when you shut the slide the lip out on the end of the slide grabs the lower seal and try's to pull it in with it pulling the seal out of the mounting track and ruining it.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 09-04-2015, 03:20 PM   #2
SilhouettePenny's Avatar
Have you raised the bed and tightened down the large metal plate with the motor attached to it. Mine only had two screws, the carpet and padding had compressed and was rocking slightly when closing. I drilled 4 additional holes plus the original four mounting holes and now it seals better. Make sure the three rollers are intact (above the seal in question) and the material above them has not been wet or starting to degrade allowing the slideout to sag.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is online now   Reply With Quote
bed, bedroom slide, roo, sabre, slide
