Old 11-16-2015, 07:16 AM   #21
TURBS's Avatar
No I have the old style
Old 11-16-2015, 08:07 AM   #22
MrNiceGuy's Avatar
I have a Crusader and would like to add the bike rack you are discussing. My concern is drilling into the frame or frame extensions to mount the rack voiding any warranties. What do you think?
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 11-16-2015, 08:09 AM   #23
TURBS's Avatar
They drill it from the factory when adding this rack see pic above
Old 11-16-2015, 09:11 AM   #24
Fulltime family RVer
Originally Posted by TURBS View Post
Attachment 94407These are how mine mount.
Thanks so much for these pics and info, Turbs and MillerTime. This is exactly what I wanted to know.
And, if it is just mounted to the support arms- then this makes my life a lot easier. I was worried that there was more support to the frame back under the camper to support this.
Now, to design a generator box to let me run them within it.
Old 11-16-2015, 09:18 AM   #25
TURBS's Avatar
I believe sabre says 450 lbs. Total weight.
The mounts I shown can be bought through sabre parts.
Old 11-16-2015, 09:32 AM   #26
I'm hoping to keep the weight down as much as possible. I need to total stuff up, though.
I think I'll call about the brackets- find out what they cost.
Old 11-16-2015, 09:56 AM   #27
TURBS's Avatar
Here's the print and pt number.
Old 11-16-2015, 06:38 PM   #28
Will the Rack work with any trailer? I had thought about adding a 2" receiver hitch but this seems better.
Orn
ornery is offline   Reply With Quote
Old 11-16-2015, 06:44 PM   #29
satdog01's Avatar
I had checked on this at Goshen, if you notice the trailer frame extends out past the trailer body, more so than other trailers. This allows for space to mount the brackets. I checked with Libert and they stated that trailer frame warranty was only good for two years. They suggeted cutting off the bumper and having an extension welded to accomitate the bike bracket, then add the bumper back to the extended frame. They offered to do it at their shop in Goshen, but time did not permitt it for me.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 11-16-2015, 07:23 PM   #30
Canadian Member
itat's Avatar
Orn
Not likely. Any TT or 5er I've seen with the LCI rack from the factory had the frame rails extended at least 6" beyond the normal configuration, in order to allow room for the rack to fold up. Without the extra length on the frame rails there may not be enough room for the brackets and rack. In any event, you'd want to verify with your frame manufacturer if your frame is designed to handle the weight of the rack and the bouncing of the load on the rack.
If you want to add a 2" receiver, don't use the ones that are installed on the bumper. Have it welded to the frame.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
bike, bike rack, sabre
