Old 06-14-2016, 08:22 PM   #1
Sabre customers hauling with F250 6.2 gasser
Quick question for you 5th wheel users. We own a 2016 Sabre 33CKTS (dry weight 10,600 LBS.) which we pull with a 2015 F250 6.2 gasser. Loaded adds another 400 to 500 LBS. Truck pulls the Sabre great on the straight and hilly highways and country roads getting to State Parks. So far we have travelled out as far 350 miles from home with no issues. As the DW and I near our next phase of life, I am asking my fellow FR brethern how far and what elevation have you traveled to with similar equipment? And for the record, Indiana has a wonderful State Park system that you are welcome to visit.
dgeck56 is offline   Reply With Quote
Old 06-14-2016, 09:39 PM   #2
Kenny kustom's Avatar
I pulled my 36qbok with the V10 F350.
Tons of power, tons of fuel.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-14-2016, 10:04 PM   #3
asquared's Avatar
I have the 34REQS and tow with a 1 ton diesel. 10,800 lbs dry weight. Loaded the 34REQS comes in at 12380 lbs with a pin weight of 2620 lbs per catscales. I have taken it through VA and NC Mountains from NC to Goshen was our farthest trip with it. The Goshen trip was 1300 miles round trip and had a combination of highways, back roads, flat land and mountains. The diesel made the trip easy. Very glad I had it. As for your rig... if it is towing comfortably and within weights I would say you are good.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-14-2016, 10:22 PM   #4
Oklahoma Proud
MillerTime's Avatar
Op...doubt you'll have a problem. But.....i bet the constant downshifting and fuel economy will make you upgrade to a diesel in the future.
I hadn't had truck that wasn't diesel in over 8 years and bought a gas half-ton a few weeks ago. (i still have my new Gmc 3500 diesel)
Im pretty disappointed in how much it downshifts on hills when empty. It actually seemed better when i went from the 17" wheels to 22" wheels. Probably the extra rotating mass that helps with momentum.
I had a 8500 puma before my current 12,000+ sabre. I couldn't imagine using a gasser on either.
If your comfortable though, then run with it!
Old 06-15-2016, 06:28 AM   #5
As long as you are under your gross combined weight rating you can travel anywhere in the country safely.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-15-2016, 12:58 PM   #6
jackandjoanne's Avatar
I tow a Silverback 29IK with a 2015 GMC Sierra 6.2 gasser, have been from Northeast Pa to South Carolina 3 times through the mountains or West Virginia and Tenn. with no issues. To upstate New York and Western Pa as well
Silverback is 11,600 dry, with the right gears the truck is rated at 14,600.
Jack and Joanne
Lakeville Pa
2015 GMC 2500 HD
2014 Silverback 29 IK
jackandjoanne is offline   Reply With Quote
Old 06-15-2016, 01:28 PM   #7
Soxfan1957's Avatar
We have a 2013 Sabre 34REQS - 6 dry weight 10700lbs. With all our gear that probably adds another 1000lbs. We tow with a Chevy 2500HD crewcab diesel. We live in western NY and have been to Maine 3 times traveled through the mountains of NH, and Vermont. To the Aderondacks of NY. To Michigan, and the upper peninsula. Traveled to Florida via Pa. WV. VA. NC. SC. through the Appalachians. And my truck never had a problem with any of the terrain.
Soxfan1957 is offline   Reply With Quote
Old 06-15-2016, 01:59 PM   #8
dwa1000's Avatar
Same unit
We have same unit our TV is the same only a 2012. I've been in the mountains in PA. Towed great. I've traveled from Philadelphia to Chicago. We also traveled to the Outter Banks off North Carolina. Never had any trouble.
dwa1000 is offline   Reply With Quote
Old 06-15-2016, 02:32 PM   #9
Another adventure awaits!
HESN22's Avatar
Same trailer and tow vehicle
Hello
We too have a 33CKTS, which we love, but it is a 2014. We tow with an F250 - gas as well. Last year we travelled from our home in Ontario to Nova Scotia via Eastern States. We took a new route ... was interesting to say the least ... we ended up at 6653 ft in the White mountains. It was a little scary at some points but we made it ... up and down. Did not wear out the brakes ... after some thought, my husband starting coming down the mountain in 4 x 4 low ... a friend who is a trucker, told us that constant steady pressure on the brakes was the way to go, as opposed to off and on ... As I said, twas an interesting trip, with a few "Holy S***" moments ... from us and people coming up the mountain towards us ... LOL
Gas mileage was not that bad, so my husband says ... was getting about 400 - 450 miles per tank ... we like travelling through the USA ... gas so much cheaper for us, even with the exchange rate and for some reason we get much better gas mileage with American Gas ...
Heading to Indiana in late August early September to visit friends.
Safe travels
Cheers
2018 Columbus Compass 377MBC
2013 F250 4 x 4 Supercab
HESN22 is offline   Reply With Quote
Old 06-15-2016, 02:53 PM   #10
Originally Posted by HESN22 View Post
Hello
Safe travels
Cheers
If you need to put your truck in 4 low.... To make it safely down the mountain. Doesn't that tell you, you need more truck???
2016 Sabre 36QBOK
Old 06-15-2016, 03:29 PM   #11
sfsgm's Avatar
Unhappy
Not only is your fuel mileage not so good but wait until you have to replace those 22" tires!!
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 06-15-2016, 03:48 PM   #12
Oklahoma Proud
MillerTime's Avatar
Fuel mileage is the same. Quality 22" truck tires aren't any more than quality 17" truck tires. About $225-300 a piece.
Im in the automotive business so tires and wheels sell a vehicle!
Old 06-15-2016, 03:50 PM   #13
RetiredRVer
I think you mean 6.0 V8, jack&joanne. The 6.2 is only available in the 1/2 ton....just sayin'!
Joe & Sandy
Mentor, Ohio
2017 Ram Laramie Longhorn Crew Cab 4X4 Cummins Diesel
2017 Coachman Chaparral 336TSIK Fifth Wheel
2018 AT 18 Alaska group
checkmate99 is offline   Reply With Quote
Old 06-15-2016, 08:37 PM   #14
We are taking favorite oldest Grandson for short camping trip next weekend.
Old 06-16-2016, 03:06 AM   #15
We pull our Sabre 32 RCTS with a 5.7 L Hemi Ram and have been doing so for 4 years with out issue. I think the 32 RCTS is a bit smaller than the 33ckts, but not by much. We've checked weights a couple of times including once using the service available at the Goshen rally and are well with in all limits. We ordered the RAM with towing in mind and equipped it accordingly.
We've camped in 23 states from east coast to as far west as Colorado and Wyoming with no problem. Our longest trip so far was last winter... 5,500 mi in 4 mo. (next winter will be longer)
There have been only a few times we wished we had more power when stopped on a pretty steep grade and had to accelerate from a dead stop. We just took it a little slower and were fine. Our Mileage ranges from 9 to almost 12 mpg with cruising average between 10 and 11. Max speed for us is usually around 55-60. We find that most comfortable.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 06-16-2016, 10:34 AM   #16
2016 Sabre 36QBOK
And your trucker friend has it backwards as well.
2016 Ram Longhorn 3500 CCLB DRW Cummins HO 4:10s
2018 Heartland Big Country 3950FB
Dan50 is offline   Reply With Quote
Old 06-16-2016, 12:03 PM   #17
100% agreed.
Constant pressure will cause brake fade. It will overheat and warp the rotors.
2016 Sabre 36QBOK
Old 06-16-2016, 01:07 PM   #18
Ddubya's Avatar
I pulled my 32 ft 5th wheel on an 8000 mile trip from Texas to California, Oregon,Washington,Idaho,Montana,North Dakota,Michigan with a 2012 f250 6.2. It did OK but several times was in 2nd gear and screaming. Mileage around 7.
Traded for a Duramax and find towing is much more enjoyable.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
Ddubya is offline   Reply With Quote
Old 06-16-2016, 02:05 PM   #19
Hello
We too have a 33CKTS, which we love, but it is a 2014. We tow with an F250 - gas ....
Sorry, but that is hard to believe. That would be 13.5 mpg if you completely used all 35 gallon capacity of the large fuel tank.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 06-16-2016, 02:43 PM   #20
TURBS's Avatar
8-9 mpg would be a bunch closern certainly not 13.5 smh
Sent from my SCH-R530U using Tapatalk
f250, gas, sabre
