Old 07-29-2015, 12:58 PM   #21
dwa1000
we had similar issues with our bedroom slide also. screws didnt hold, not long enough or big enough. our small slide motor always sounds like it is overloaded. I added a bracket like you mentioned here too as it didn't seem like just tightening the loose screws would remedy this long term.
JoeNanMinn is offline   Reply With Quote
Old 09-04-2015, 10:56 PM   #22
SilhouettePenny's Avatar
Originally Posted by dwa1000 View Post
I noticed the bedroom slide was working at a slight angle when going in and out. I opened the bed to view the slide and found the metal slide was not screwed in all the way to the wood brace on one side. I screwed it all the way in and it works better. As I looked at the wood support it looks twisted. I'm thinking of adding some small "L" bracket to support it. Has anyone else seen problems here?
The wood supports under my bed for the lift rods/shocks were distorted so I just removed the rods, don't really use that area anyway. My base plate was also loose and missing screws. Tightened and added more attaching hardware then took it one step farther and removed the plywood at the head of the bed, the area that hangs outside the wall when extended. Filled this cavity with insulation to help with heat retention in cold weather. Too much trouble to access under bed storage after adding mattress topper so we store permanent items like the original bed cover. Check your screw length so as not to drill into a water pipe below.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 09-09-2015, 02:24 PM   #23
We have had our Sabre select 29rlds for a year now. We have had a few minor issues, but nothing major that stopped us from using it. Have camped about 40 nights in since new. We are headed for Montana next week for a couple of weeks and expect no problems. Love the rig and our dealer. This is the sixth rv we have had, so we know what to expect out of them.
Dsweet is offline   Reply With Quote
Old 10-11-2015, 07:29 PM   #24
We bought a 292rlds a year ago and have just a couple small problems. Our dealer ( Open Road) in Monroe Wa. Fixed them with no hassles. We ate fortunate to have a good dealer within 8 miles of our house! Love our fifth wheel and have used it about 40 nights this year and over 4,000 miles. Work out the bugs and too will love it. Happy camping.
Old 01-06-2016, 07:31 PM   #25
Buckeye Chuck, where have you traveled to with your unit and what are you pulling it with?
dgeck56 is offline   Reply With Quote
Old 01-06-2016, 08:10 PM   #26
BuckeyeChuck's Avatar
We pulled it from Grand Rapids, Mi to Sandusky, Ohio about 250 miles each way. Mostly flat roads with one steep grade just south of Grand Rapids. No problems pulling with a F250, 6.2L gasser, 3.73 gears. Got a little over 10 MPG. Towed at 63 - 65 mph. That was our longest so far. Heading to Florida next fall from Michigan with stops in Nashville and Savana. I don't anticipate any problems.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 02-09-2016, 08:19 AM   #27
I am having problems with wa ter pressure in the shower. Any tips to try?
Mike48413 is offline   Reply With Quote
Old 02-09-2016, 08:35 AM   #28
Have you made sure there is nothing caught in the hose leading to the shower head? And take a good look at the shower head itself for any blockage.
Old 02-09-2016, 09:12 AM   #29
Yes I've already checked and changed the shower head
Old 02-09-2016, 09:32 AM   #30
TURBS's Avatar
Sabre issues
Mike 48413 On my Sabre both hoses in the basement leading up to the shower made a sharp bend, they put 90 degree hose benders on them but they still kinked.
I'd start there sir.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
sabre
