Old 06-07-2016, 10:23 AM   #1
RoadDog66's Avatar
Sabre Lite 28BH vs HD 2500
Looking at a 28BH 5'er, but wanted to make sure I'm not putting the cart before the horse so to speak. What are your weight & towing thoughts. (I'm sure the payload numbers will be close when the truck is loaded up because of the added hitch weight). Thanks in advance.
TOW VEHICLE
Ram 2500 6.4 Hemi
Tow Cap: 12,600 lb
Payload: 2920 lb
GVWR: 10,000 lb
GAWR F: 5500 lb
GAWR R: 6500 lb
CGVWR: 19,800 lb
5TH WHEEL
Sabre Lite 28BH
Dry Weight: 8458 lbTH
Pin Weight (dry): 1530 lb
CGVWR: 11,565 lb
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 06-09-2016, 08:28 AM   #2
RoadDog66's Avatar
Well I think we are pulling the trigger on the SL 28BH. I'm pretty confident it will tow just fine after conferring with other HD 6.4 owners & B&W owners.
BC: Ram OEM
Old 06-09-2016, 09:56 AM   #3
TOW VEHICLE
Ram 2500 6.4 Hemi
Tow Cap: 12,600 lb
Payload: 2920 lb
GVWR: 10,000 lb
GAWR F: 5500 lb
GAWR R: 6500 lb
CGVWR: 19,800 lb
5TH WHEEL
Sabre Lite 28BH
CGVWR: 11,565 lb
Yeah, your pin weight might get a little tight with the 2500 depending on how many people in the truck and how crazy you get loading up. Power wise you'll be more than fine. Especially if you have 4.10s.
2015 Ram 3500 CC SRW SB 6.7 Diesel Powered Baby! 2015 Sabre 36QBOK-7
2015 Nights Camped: 23
2016 Nights Camped: 27
2017 Nights Camped: 29
2018 Nights Camped: 4
mikeysotp is offline   Reply With Quote
Old 06-09-2016, 11:46 AM   #4
RoadDog66's Avatar
Nah 3.73's but not too concerned. I know of guys pulling 3K more than I'll be with them and they say it's fine.
I'm figuring the real world pin wt will likely be closer 1850 lbs and other than 425 lbs of fahimily (including me) and 350 lbs of hitch there should be 300 lb for misc. I'll be sure to load up the 5'er before the truck.
My neighbor pulls a 41 ft 5'er at 14K loaded with his 2500 CTD and his payload is less than mine. He's got a lift and 37" tires too. Not saying it's safe, just that it can be done. With 6500 lb rear axle ratings its more the DOT limited 10K GVWR that hinders us.
BC: Ram OEM
Old 06-15-2016, 08:57 PM   #5
RoadDog66's Avatar
Decided against the Sabre Lite. Went and saw it in person and just wasn't as impressed in person as I was on paper for a $44K 5th wheel. We are going with a Grand Design instead. Stepped inside one and was sold. This is great forum so I'll certainty stick around.
BC: Ram OEM
28bh, 500, sabre
