04-09-2016, 12:28 PM
Second Air Conditioner on 2015 33'Sabre
I am considering adding a second AC unit (13,500 Btu Coleman-Mach 3)over our bed. Vent, power, and stat wiring is already in place. There is duct available tying into the main duct going back to the main unit. Do you block or leave connected the duct between the living area and bedroom or is it best to use a non ducted unit to just treat the bedroom? My main AC is a 15k Btu Dometic Brisk 2. It has difficulty cooling the unit in the Florida sun. It also is very noisy. Located over the TV makes it difficult to hear the TV without the volume way up. I can't imagine trying to sleep under the Dometic. Any suggestions on a better AC selection would be appreciated. I am trying go low noise and light weight.
04-09-2016, 12:32 PM
Get a ducted unit and appropriate items and leave the duct work as is DO NOT block one from the other.
I just installed a 13.5k ducted on my unit.
If you want quiet do not install an a/c in your bedroom.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
04-09-2016, 01:01 PM
Thank you for the comments. Maybe the answer is put the unit in the bedroom, but turn it off at night and let the main unit do the cooling. If it supplemented the main unit during the day, together they would be able to cool the camper. At night the load is light and the main unit can provide the necessary cooling.
04-09-2016, 01:04 PM
Do you have a 50 amp service?
If only 30 amp you will not be able to run BOTH at the same time during the day.
04-09-2016, 01:11 PM
Yes, it is equipped with a 50 amp supply.
04-09-2016, 01:22 PM
loud air conditioner
I am a new really new member on the forum the issue about air conditioner made me hopeful u or someone may be able to help us. we have a 24 ft Surveyor trailer new in 2015 and the air conditioner noise is terrible the air conditioner is in kitchen area any suggestions what we can do or do we have to get a different ac it it ducted and due to health issues haven't been out often we have a 30 amp system by now u can tell JoAnn is writing not her husband who could have given u more technical info but if you are able to offer suggestions will get him into forum we do have an appointment this month at Lazy Days in Seffner Fl to see if service dept can help. But nothing like talking to a fellow FROG owner thanx JoAnn and Mo
04-09-2016, 01:32 PM
I installed mine ducted works great. If running at night it cycles a lot tho, I usually just run the fan only on low at night helps drown out the campground noise.
04-14-2016, 11:19 AM
My wife and I like the noise the unit makes. it drowns out any outside noises that may be around at the campground and we sleep well.
04-14-2016, 11:25 AM
Always Learning
For TV, we bought headphones.
04-14-2016, 11:28 AM
Georgia Rally Coordinator
At night I just turn on the living area AC on and leave the one in the bedroom off. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-14-2016, 11:41 AM
I agree !
