Old 09-11-2015, 05:39 PM   #1
Tire wear
Ok, I have been towing my 5r for three years now but have a novice question. Will the rear tires wear out faster than the front because of towing? I realized this week that my rear tires are almost down to the legal limit with about 26,000 miles on them of which I have towed 13,494 miles. (This is on a 2013 Ford Super Duty, please no comment about this would not happen on a Chevy or a Ram) I do rotate my tires twice a year but of course the same two always end up on the rear just as I begin towing season. The fronts still have 10/32.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-11-2015, 06:07 PM   #2
toslow's Avatar
are you checking tire pressure on a reg bases?
haven a blast
toslow is offline   Reply With Quote
Old 09-11-2015, 06:12 PM   #3
Constantly. 65 Front/80 back.
So to my original question. SHOULD rear tires wear faster because of towing?
Old 09-11-2015, 06:13 PM   #4
toslow's Avatar
i have a 03 ram dually and have the same thing, plus the two outside tires wear faster then the inside
haven a blast
Old 09-11-2015, 07:11 PM   #5
Brother Les's Avatar
Change your time line of tire rotation to the middle of the towing season. 'Should' rear tires wear out faster....? they should all 'wear out' at the same rate. Rotate them more often.
Brother Les
Old 09-11-2015, 07:17 PM   #6
BACK TIRES WILL WEAR OUT FASTER due to there the ones doing all the work and carrying most of the weight - try rotating them more often it may help.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 09-11-2015, 11:32 PM   #7
maddog69's Avatar
Also I run much lower rear air pressure when I don't have a load in or on my F350 otherwise it will wear out the centers really fast
maddog69 is offline   Reply With Quote
Old 09-12-2015, 04:27 AM   #8
SilhouettePenny's Avatar
Next time you make a tight turn while towing look back at the contact point where the tire on the back axle meets the road. See that sideways scuffing action! In my opinion that's the reason for stronger S/T sidewalls AND the reason rear axle tires wear faster. Front axle probably has more weight allowing rear tires to "walk". Just my 2 cents. Or I could instigate the nitro/air debate again and suggest you have nitrogen in the front axle tires and air in the rear tires.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 09-12-2015, 11:56 AM   #9
Penny;
Sorry I was not more clear. i was discussing my truck (TV) tires wearing. Not my trailer.
My bad.
Old 09-12-2015, 06:09 PM   #10
No sir, my bad...reading the forum at 4 am was my problem. Hope you find a solution.
tire
