Old 01-09-2016, 10:07 AM   #11
fonzie's Avatar
Is there enough water in fresh water tank? Don't rely on indicators. I would put more water in it and test again.
Fonzie
Old 01-09-2016, 10:09 AM   #12
Ford Idaho's Avatar
As I understand a running pump with no pressure build up indicates a leak.
Have you located a leak/s?
Old 01-09-2016, 11:22 AM   #13
OK, so I added more water to FW tank and turned the pump on. No pump! Turned a faucet on and apparently still had some city water pressure in the system. Drained that and turned the pump back on and it started running but still no pressure build up. Checking all around for leaks but so far found none. Checked the fuse again, still OK. Is there a diaphragm or something that could be bad or is it a pump replace? Appreciate your help so far and one good thing out of this- I found the pump and the guts behind the furnace and wh. Lots of sawdust too
davidgle is offline   Reply With Quote
Old 01-09-2016, 12:51 PM   #14
fonzie's Avatar
Are you located where it could have froze and crack input line or strainer from fresh water tank? The pump is usually a Shurflo diaphragm pump......either pump is bad, input line is blocked or air is getting in the input line.....check strainer before pump for debris or if cracked....also make sure battery voltage is 12 volts and more for pump to operate properly....
Fonzie
Old 01-09-2016, 01:50 PM   #15
Thanks, I'll check the hose before the pump. I am on shore power with good fuses so is it OK to assume I have 12v at the pump?
Old 01-10-2016, 05:54 AM   #16
fonzie's Avatar
Well if pump is running as you said in post #10 then you do have voltage at the pump but it might be low. So just check voltage at battery with multimeter to confirm you have at least 12 volts.......
Fonzie
Old 01-10-2016, 06:26 AM   #17
Where you live by now you/someone should have Winterized! since you didnt know where the Pump was located,maybe whoever Did the Winterizing left the Valve turned for that? Regardless how much water is in the F/W tank the Pump will NOT draw from tank! Youroo!!
Old 01-10-2016, 06:31 AM   #18
markb5900's Avatar
Agree with youroo that there could be a valve still turned off from winterizing.
I have had a pump fail before, but when it did, it just wouldn't run at all.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 01-10-2016, 06:52 AM   #19
nomad297's Avatar
Bingo!
Bruce
Old 01-10-2016, 06:49 PM   #20
SilhouettePenny's Avatar
On the inlet side of the pump is a strainer/wire screen filter device. NO TOOLS on this thin plastic, just screw it off with your hand and determine if it's clogged. Check the gasket and reinstall.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
pump, water, water pump
