Old 01-07-2016, 04:25 PM   #1
Water Pump- where is it
We have a 2013 Sabre 32-RCTS bought new in 2013. Apparently starting to show a little age. For the life of me, I cannot locate the water pump. It worked fine at home and for the first night on the road. Then, no water pump. Thankfully, we are now on city water but need to fix it before we head home. I've checked fuses but since I don't know where the pump is Do you have a similar unit and have you found the location?
davidgle is offline   Reply With Quote
Old 01-07-2016, 04:26 PM   #2
TURBS's Avatar
Look in the basement behind the convenience center, you'll have to remove a panel.
There's an in line fuse by the pump as well.
Sent from my SM-G900R4 using Tapatalk
Old 01-07-2016, 04:38 PM   #3
Turbs, I kind of looked over the panel and only saw hose. Guess I'll have to take the panel off and dig deeper. Thanks!
Old 01-07-2016, 04:41 PM   #4
TURBS's Avatar
It's behind the panel I left the panel out.
Old 01-07-2016, 04:42 PM   #5
TURBS's Avatar
Should be two screws at the bottom
Old 01-08-2016, 11:55 AM   #6
SilhouettePenny's Avatar
Remove a couple of square drive screws at the bottom of the panel. Then behind the next panel you should locate the water pump. I also left these panels off to gain more basement storage space. Just a few inches off the pump is an inline fuse.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 01-08-2016, 12:16 PM   #7
TURBS's Avatar
Yep!
Old 01-08-2016, 02:37 PM   #8
Water pump- where is it
Thanks for the responses. Looks like I have a little work ahead but I'll be able to clean up some of the sawdust left behind during the build.
Old 01-08-2016, 09:46 PM   #9
We have a 2014 Surveyor- There is a panel under the bathroom sink that has the water pump in it. You must remove the 4 screws to get it off.
2014 32 RKDS Surveyor
2013 Dodge Ram 2500
Crazy Cocker Spaniel Daisy-Ruler of the Roost.
6 months in Florida 6 months in Michigan
SusanML4650 is offline   Reply With Quote
Old 01-09-2016, 10:54 AM   #10
Well, I found the pump and checked the inline fuse. The pump is running but not as loud as normal. There is no pressure build up. Time ti replace or other ideas?
pump, water, water pump
