03-02-2014, 06:15 PM
#61
Originally Posted by ependydad
Turbo, I don't know of each outlet is satellite friendly.
Maybe sam can shed some light on it.
TURBS
Think spring!
The last man standing also has a sharpie
03-02-2014, 09:42 PM
#62
Here to Help
Originally Posted by MillerTime
X3 - ice maker would be awsome!!
oops. forgot to check mark that stupid box again!
Icemaker...I like it. Rather than taking up freezer space in the refer, what about the free standing ice makers?
03-02-2014, 09:48 PM
#63
Here to Help
SAT wiring
TURBS
Think spring!
Team Improvements...lol.
We struggle with the satellite wiring in the units due to all the combinations of receive locations. For example, do we wire it to have one receiver in the living room feeding the other bedrooms? Do we just do a loop so you can have a receiver in each bedroom and the a separate feed from the dish. If you can help me design a "reasonable" cost solution, I'm listening.
03-02-2014, 09:49 PM
#64
Oklahoma Proud
That would be awsome. Maybe it could be in an overhead cabinet with a pull out drawer of ice that hung below the cabinet 5 or 6". Don't know if its possible like that. May just have to have a pull out lower shelf with the icemaker mounted on it or something.
03-02-2014, 10:01 PM
#65
I'll work on that!
But unless its changed there is no place to put a receiver
What you need is a switch I believe.
A-b-c
Main coax goes the main tv then it can be switched to a "main tv" b "bedroom" c "bunk house"
A fancier switch would go something like this.
A b or c
A and b
A and c
B and c
Pretty much what you use for your gaming switch.
Luckily I have a uhf reciver so I can mount it in the basement as my receiver doesnt need to "see" the remote to change channels.
TURBS
Think spring!
03-02-2014, 10:03 PM
#66
Here to Help
Ice maker
Would you choose to have the icemaker take up room in your pass through compartment or your kitchen?
03-02-2014, 10:05 PM
#67
Here to Help
I'll work on that!
A-b-c
A b or c
A and b
A and c
B and c
TURBS
Think spring!
So with todays technology, are we to the place where we would only have a main receive and then "hoppers" for other TV's
03-02-2014, 10:09 PM
#68
Glass door panel instead of wood on door over Genesis unit. PITA to leave the door open to have the remote 'talk' to the unit.
03-02-2014, 10:18 PM
#69
Here to Help
Gota ya, good to hear from you Wiscampsin!
#70
What about adding a plastic conduit, that goes from behind main TV to bunkhouse TV and to master bedroom TV area? That's what I do when I frame houses for people, add a couple runs in places they may want later on, with a full size biz and single gang cover plate at the ends
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
03-02-2014, 10:23 PM
#71
Here to Help
Conduit idea
Sent by me
Thanks jtstromsburg, great idea. I know Columbus has had some success running a conduit from the pass through compartment up to the attic area.
Thanks.
03-02-2014, 10:24 PM
#72
Are we there yet.......
Why was a knife holder not put in the 36qbok? Nor a med cabinet in the 1/2 bath.
03-02-2014, 10:37 PM
#73
I would like to see the steps hinged for shoe storage. Also a surge protector as a built in option would be good. Having the outdoor kitchen lowered without the countertops for those of us who are on the short side. In the QBOK a lock on the half bath door seems easy enough
I would like to see a dishwasher drawer in the area under the fridge.
I second the vacuum dust pan and ice maker
2014 Sabre 36QBOK - 7.......sort of
03-02-2014, 10:46 PM
#74
Laundry hamper in place of the cabinet by the stool. A tilt out style.
03-03-2014, 06:32 AM
#75
RE: Shoe rack
32ckts... are you asking because you own a 32rcts
I was asking I wanted to see what is looked like. We've been thru the 32CKTS at a recent show and don't recall seeing it. I may want to copy it as a mod for the 32rcts.
Thank Sabre Sam!
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
03-03-2014, 06:54 AM
#76
Oklahoma Proud
Hmmmm. Well 6 of 1, half dozen of the other. A case could be made for both.
Or even in outside kitchen on models with them.
03-03-2014, 08:16 AM
#77
The Dually
The five function analog remote to run the four slide-outs and
rear electric stabilizer jacks.
Instead of awning an door lights.
When ordering it with leveling system option.
"Sabresam Comment"
03-03-2014, 09:09 AM
#78
This one's from DW - toe kick area at bottom of base cabinet in front of galley sink.
03-03-2014, 01:34 PM
#79
Here to Help
Your Questions
I'm 99% sure we had to delete the knife holder due to a new RVIA code about flammable things close to the stove. I need to have someone visit the possibility of having slits cut in the solid surface pc we now use. No good answer on the med cabinet other than PD picked to do that. I will forward your comment.
#80
Here to Help
Toe kick
Tell DW thanks. I will include in my summary to PD.
