Originally Posted by Fritiz
Hello Located in the fuse box under or below the stove. 15 amps fuse last one below.
I have the same problem and pulled the fuse out. It was causing my batteries to come low. Theirs a short some where on the step wires and have not found it yet. But since I pulled the fuse out my batteries are staying charge a lot longer! When you pull the fuse out your radio and dvd player will also be out of power closed.
Fritiz,
I replaced the motor in the step. I figured out that the shaft in the motor was the real problem. The shaft and a serious wear spot on it and it was binding up and would get stuck. Then it would blow the fuse. Easy fix if you can get the trouble shooting correct. It took no time replacing the motor, 3-4 bolts. Good luck with your repairs. Guys on this forum are great with sharing advice and experience. I have save a ton of money using this Forum. Thanks to all.
