Old 07-13-2016, 11:18 PM   #1
2401R side view cameras
My MBS came with side view cameras, but point too far upward. I see a lot of sky and clouds. What I can't see on a bright day is the car next to me because the automatic exposure control darkens the sky too much. Not a prodpblem at night. I have tried to adjust both of them down but they don't move. My dealer tells me they are not adjustable.
Aspenmeadow is offline   Reply With Quote
Old 07-15-2016, 05:56 AM   #2
2016 Solera 24W
hfalbright's Avatar
Side View Cameras Relocated
I have a 2016 24WS that had the side view cameras mounted on the front fenders near the headlights. I moved them back to the coach where they now put them on the new models. The cameras are not adjustable. What I found is that they were attached with adhesive mounting tape. There was also a backing nut on them when mounted on the front fenders. I do not know if there is still a backing nut on them now that they are on the coach or not. If not, you should be able to peel them off enough to remove and reapply mounting tape, and reposition them. You may be able to determine whether or not there is a backing nut on them by reaching up into the area where they are mounted. I did not put the backing nuts back on when I relocated mine because the threaded mounting stem was not long enough to allow it. The heavy duty mounting tape holds them just fine.
Harry
2016 Solera 24W
hfalbright is offline   Reply With Quote
