Old 05-10-2019, 12:09 AM   #1
2401S Forester. Where is fresh water tank drain?
Just got rig. Sanitizing the tank and canít find where to drain it. Can anyone advise? Thanks!
suscamper is offline   Reply With Quote
Old 05-10-2019, 12:59 AM   #2
2012 Solera
On our 2012 Solera S, the fresh tank drain is via a valve accessed through a black “door” on the back panel of the large exterior storage compartment (last compartment on the passenger side). If I remove the “door” the valve is in a pex pipe somewhat below the opening. With the 1/4 turn valve open, the fresh water drains through the spare tire.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 05-10-2019, 02:04 AM   #3
namusmc's Avatar
On mine, located in the rear passenger side a few inches in from bumper. On the underside, unscrew the white plastic port cover and you will see the drain lines tuck
ed inside that cavity.
namusmc is offline   Reply With Quote
Old 06-05-2019, 06:56 PM   #4
Fresh Water Drain Valve
In my 2401R, drain valve is located next to my water pump. It's connected to the blue plastic pipe which extends through the floor board.
GMara is offline   Reply With Quote
Old 07-08-2019, 09:26 AM   #5
Same with my 2016 2401R, there's a valve inside the compartment with the water pump.
2016 MBS Forester 2401R
baranski is offline   Reply With Quote
drain, forester, fresh water, tank, water, water tank
