Old 08-08-2016, 12:51 PM   #1
24W water filter
Just discovered that the water filter housing under sink has come loose. Looking at it, the only way I can see to reattach it is to remove the sink. Has anyone else had this happen? I guess I could relocate it and re-pipe it. Any thoughts? Thanks.
Rogerbruchay is offline   Reply With Quote
Old 08-08-2016, 01:45 PM   #2
Petersb's Avatar
Things I've seen on the forum do away with the filter plumb it straight through others have said they are a problem anyway. They can leak or break causing a flood.
Petersb is offline   Reply With Quote
Old 08-08-2016, 07:13 PM   #3
Also one less thing to deal with when winterizing
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 08-09-2016, 01:23 PM   #4
Loefflerh's Avatar
Will do the straight thru plumbing too.....I use an outside filter and that gives more cabinet space.
What is needed to do it? Pictures?
Hans
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - Sep 2021
Entegra 27A Oct 2021 - ?
Loefflerh is offline   Reply With Quote
Old 08-09-2016, 03:42 PM   #5
hkreck's Avatar
A six inch pipe nipple (brass or quality plastic) with standard 1/2" pipe thread will simply replace the entire filter assembly. All you need to do is unthread the brass pipe adapters that connect to the filter assembly and substitute the pipe nipple. The use of Teflon tape or an appropriate pipe dope is best. Nothing to it.
This is what I was told a couple of years ago about removing the filter housing and it worked.
Henry & Tena
hkreck is offline   Reply With Quote
water, water filter
« Rant | Wondering »
