03-17-2016, 11:34 AM
A/C
In my 2016 24R we used the roof air for the first time. It drove us crazy cycling through and set at 73. Has anyone had this issue?
Dogpa
John Craft
dogpa
2016 Solera 24R
03-17-2016, 11:45 AM
I don't have an RV like yours, but we have experienced something similar. If we set our thermostat to 72 or 73, the unit cycles quite often. If we bump it up to 74 or down to 71 the cycles are greatly reduced without any ill effects to the ability to keep the TT cool. I think these thermostats have some quirks.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
03-17-2016, 01:03 PM
Dogpa
Similar issue on my 2014 24R. Like others mentioned, bump it up or down a degree or two usually solves the problem.
2014 Solera 24R
USN Retired
03-17-2016, 02:03 PM
Thanks for tips. Phew no dealer involved.
Dogpa
John Craft
dogpa
2016 Solera 24R
03-18-2016, 09:24 AM
After another sleepless noisy night I have attempted to contact FR. I tried all settings to no avail blues it would be nice to have the owners manual.
Dogpa
John Craft
dogpa
2016 Solera 24R
03-18-2016, 10:08 AM
2012 Solera
Is the AC fan cycling on and off what is the problem? If so, try setting the fan at the thermostat to "Hi" or "Lo" instead of "Au" (auto). Select fan then use "+" or "-" to choose hi or Lo, then select AC. On hi or Lo the fan runs continuously and just the compressor switches on and off with temperature.
There is also a way (with our Dometic 13.5K AC) to change the temp swing allowed between cycles, but I don't remember the details. In the manual somewhere.
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
03-18-2016, 10:16 AM
Georgia Rally Coordinator
Jim
X 2 Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-18-2016, 10:34 AM
I don't know what thermostat you have but if it is an inexpensive analog stat, swapping it for a digital will help. Many analog stats cycle both the A/C and the furnace way more than necessary because of their swing.
Change this type...
For this type...
03-18-2016, 02:40 PM
Jim
"To set the temperature differential the system must be Off. Press the “―” button and, while holding it, also press and hold the On/Off Mode button for three seconds. Release the On/Off Mode button. Then release the “―” button. Press the “+” button to toggle between “d1” and “d2”, “d1” for 1 degree F differential and “d2” for 2 de- grees F differential."
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
03-18-2016, 04:02 PM
Also....be sure a supply register is not blowing towards the thermostat.The cool air will cycle the stat too fast.
2016 Forester 2401WS MBS
Life is short...eat the cookie
03-18-2016, 04:22 PM
Dogpa
This is a thermostat problem. Here is the one I believe you have.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-18-2016, 05:24 PM
Dogpa
Try opening the overhead grate in the dining area when you go to bed and close the sliding door. Make sure the bedroom overhead register is not pointing at the thermostat.
2014 Solera 24R
USN Retired
03-19-2016, 06:59 PM
Have been in the Rio Grande Valley of Texas the past month with our MBS and have used my 13.5 AC extensively. Set the fan on lo and temp at 74 or 75. Can hardly hear the compressor kicking in and out but the fan is quite noisy.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
