Old 03-17-2016, 11:34 AM   #1
A/C
In my 2016 24R we used the roof air for the first time. It drove us crazy cycling through and set at 73. Has anyone had this issue?
Dogpa
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 03-17-2016, 11:45 AM   #2
I don't have an RV like yours, but we have experienced something similar. If we set our thermostat to 72 or 73, the unit cycles quite often. If we bump it up to 74 or down to 71 the cycles are greatly reduced without any ill effects to the ability to keep the TT cool. I think these thermostats have some quirks.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-17-2016, 01:03 PM   #3
Mikegjax's Avatar
Dogpa
Similar issue on my 2014 24R. Like others mentioned, bump it up or down a degree or two usually solves the problem.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-17-2016, 02:03 PM   #4
Thanks for tips. Phew no dealer involved.
Dogpa
John Craft
dogpa
2016 Solera 24R
Old 03-18-2016, 09:24 AM   #5
After another sleepless noisy night I have attempted to contact FR. I tried all settings to no avail blues it would be nice to have the owners manual.
Dogpa
John Craft
dogpa
2016 Solera 24R
Old 03-18-2016, 10:08 AM   #6
2012 Solera
Is the AC fan cycling on and off what is the problem? If so, try setting the fan at the thermostat to "Hi" or "Lo" instead of "Au" (auto). Select fan then use "+" or "-" to choose hi or Lo, then select AC. On hi or Lo the fan runs continuously and just the compressor switches on and off with temperature.
There is also a way (with our Dometic 13.5K AC) to change the temp swing allowed between cycles, but I don't remember the details. In the manual somewhere.
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 03-18-2016, 10:16 AM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
Jim
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 03-18-2016, 10:34 AM   #8
Pickin' & Campin'
I don't know what thermostat you have but if it is an inexpensive analog stat, swapping it for a digital will help. Many analog stats cycle both the A/C and the furnace way more than necessary because of their swing.
Change this type...
For this type...
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-18-2016, 02:40 PM   #9
MNtraveler's Avatar
Jim
"To set the temperature differential the system must be Off. Press the ― button and, while holding it, also press and hold the On/Off Mode button for three seconds. Release the On/Off Mode button. Then release the ― button. Press the + button to toggle between d1 and d2, d1 for 1 degree F differential and d2 for 2 de- grees F differential."
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 03-18-2016, 04:02 PM   #10
bob dirt's Avatar
Also....be sure a supply register is not blowing towards the thermostat.The cool air will cycle the stat too fast.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
