Old 08-26-2016, 03:19 PM   #11
fonzie's Avatar
This is double post....
Propane vs Electric for AC and More
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 08-26-2016, 04:32 PM   #12
Mikegjax's Avatar
Btw, check and reset the breaker on the gen itself.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-26-2016, 06:04 PM   #13
It is a Forest River Forester 2401W on a MBS chassis. We have never used the gen set to power the RV but have tested is coming on since we picked up the RV in Feb 2016 (so yes, new). The generator starts fine but doesn't seem to "power" the AC or the fridge. The generator is a 3600 Onan LP and the propane tank is 3/4 full.
wagntail is offline   Reply With Quote
Old 08-26-2016, 06:42 PM   #14
where is it? have looked everywhere and it does not shut off just does not power ac or fridge
Old 08-26-2016, 06:47 PM   #15
Head Rambler
Do you know if the transfer switch is switching from shore power to generator?
I'm not familiar with your coach, but do you have a manual or automatic transfer switch?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-26-2016, 06:56 PM   #16
it is supposed to have an automatic generator transfer switch but have no idea where this is. I can turn on the generator either from the control panel in the coach or outside on the generator when I take the cover panel off
Old 08-26-2016, 07:10 PM   #17
fonzie's Avatar
There should be a breaker on the generator control panel.....
https://powersuite.cummins.com/PS5/P...am/spd_qd7.pdf
Fonzie
Old 08-26-2016, 08:45 PM   #18
Is the microwave powered?
If it is, then the transfer switch is working and allowing the generator to power the AC bus. If not, then the transfer switch may have failed.
KatanaPilot is offline   Reply With Quote
Old 08-26-2016, 08:51 PM   #19
this is not my generator. mine has the control panel in the middle and there is no apparent breaker. mine is a onan 3600 LP
Old 08-26-2016, 09:09 PM   #20
Flybob's Avatar
[QUOTE=fonzie;1301109]This is double post....
Threads merged.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
electric, generator, propane
