Old 08-26-2016, 01:21 PM   #1
AC on Propane Generator vs Electric
We are getting ready in a few weeks to take the RV out and will have some dry camping and will need to use the generator for the fridge and AC. I turned the generator on today and it started easily but then I set our thermostat to AC and went out for about an hour and when I went back in no AC and temp was over 85. Nothing else was on in the RV that I know of. Checked all breakers in the RV and all seem fine. Before I call for a service appointment, what should I try? Have a 2016 2401W and we've always plugged in thus far. Thanks,
wagntail is offline   Reply With Quote
Old 08-26-2016, 02:54 PM   #2
TURBS's Avatar
What size generator?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-26-2016, 02:56 PM   #3
TURBS's Avatar
Remember your converter is a constant and draws 2-8 amps
2015 Columbus 320RS
2008 2500HD Duramax
Old 08-26-2016, 03:17 PM   #4
RSchleder's Avatar
Why was the A/C off? Did the generator quit? Was the breaker on the generator tripped?
We had a propane generator in one of our small MH's and when it was above 90 degrees outside, the generator would run and the A/C was fine for a while. After about 20-30 minutes, the generator would sputter and quit. Finally replaced the propane regulator on the generator and that cured the issue. I have since read that these regulators are made in China and the quality/reliability is extremely poor.
Days camping (2016)----181 days
Days camping (2017) --- 21 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 08-26-2016, 03:23 PM   #5
The generator is an Onan 3600 LP and starts up just fine. I don't think the AC ever turned on but will try again to be sure. AC works fine on electric. Checked the breaker panel above the fridge but is there a separate breaker for the generator outside? Thanks for any help!
Old 08-26-2016, 03:34 PM   #6
RSchleder's Avatar
Yes, I'm pretty sure there should be a separate breaker ON the generator, not positive though!
30 years RV'ing
12 different RV's
Old 08-26-2016, 04:03 PM   #7
Generator is running just fine but just tested the fridge alone and it does not come on with gas only?
Old 08-26-2016, 04:07 PM   #8
fonzie's Avatar
There is always a main breaker on generator, just need to find it and make sure it is closed (on)....if on then maybe your auto-transfer switch is not working properly.....
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 08-26-2016, 04:11 PM   #9
Georgia Frog Rally 2017
aceinspp's Avatar
What type of camper is the gen in? Is the camper new? Have you ever use the Gen set before. I had a camper once that you had to plug the power cord into a socket where the power cord is housed. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-26-2016, 04:17 PM   #10
Mikegjax's Avatar
Is your generator diesel or gas? Is your AC a 13000 btu or a Dom. 15,000 btu unit.
I have read that the diesel gen would not power the Dom 15,000 btu unit, but could handle an Attwood 15,000. Don't know if that is you problem, but an idea.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
electric, generator, propane
