Old 08-15-2018, 01:31 PM   #1
AudiDudi's Avatar
Adding non-pressurized water to FW tank
Has anyone found a method for adding water to the fresh water tank with out a pressurized hose?
On my Prism 24G, there is only a switch that allows a pressured hose to either fill the tank or to provide "city water". It would be nice to have a method to add water when in a campground that has water faucets but no hookups.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is online now   Reply With Quote
Old 08-15-2018, 03:33 PM   #2
Fulltime family RVer
Do you have a winterization valve that would normally be used to suck anti-freeze?
ependydad is online now   Reply With Quote
Old 08-15-2018, 03:46 PM   #3
AudiDudi's Avatar
If I do, I have no idea where it is. The water pump itself is pretty inaccessible being behind a couple drawers attached to the outside wall under the stove.
I have not had a need to winterize as the Prism is in AZ from Oct to April.
Mike and JoAnne
Old 08-15-2018, 06:03 PM   #4
Dbrote's Avatar
We have a Sunseeker 2400R. I have had to add water a couple of times and so what I do is carry an empty 6 gallon water tank. I fill up the water tank and then put the winterizing tube into the tank. Change the valve to winterizing and then I open the outside sprayer and hold it to the fresh water intake. They are right next to each other. Next turn on the water pump and presto. The water is sucked up into the sprayer and then shot into the fresh water tank. Bingo. Fresh water added. Donít ask me why I needed to add the water please.
Dbrote is offline   Reply With Quote
Old 08-15-2018, 06:11 PM   #5
I'm not sure what you mean....
Would something like this water bandit work
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 08-15-2018, 09:34 PM   #6
AudiDudi's Avatar
That might work if one is close enough to the faucet. I just got one of those today from FedEx.
Mike and JoAnne
Old 08-16-2018, 11:20 AM   #7
Original manufacturer was called "water thief" I think. What also helps with these is to put a hose clamp that can be tightened down as these do tend to leak when in use.
2019 Tiffen Allegro Open Road 32SA
F53 / 24000# Chassis
2008 Jeep JKS
Ready Brute Elite / Blue Ox BP
High Desert is offline   Reply With Quote
Old 08-16-2018, 11:40 AM   #8
AudiDudi's Avatar
A hose clamp is a great idea!!
Mike and JoAnne
Old 08-16-2018, 12:40 PM   #9
rmanduch's Avatar
I bought a cheap portable sump pump with a hose connector and put it in a 5 gallon pail and pour water from my 7 gallon water jugs into the 5 gallon pail and let the sump pump do the rest.
rmanduch is offline   Reply With Quote
Old 08-16-2018, 03:12 PM   #10
AudiDudi's Avatar
Sounds doable - thanks.
Mike and JoAnne
tank, water
