Old 08-29-2016, 02:57 PM   #11
Ok, I removed the lower drawer to find the fuse but it was stashed full of wires and a heater hose and insulation crap.
Better way is to unscrew the switch plate where the awning lights which is and pull it out gently there is a three amp fuse connected to the awning switch. When I pulled the fuse it was obvious that it was blown so what did I learn, it is better to work with electricity when it's in the off position less likely to blow fuses etc. I have attached three photos give you a clear view of the switch plate and a fuse holder and now I'm off to the store for more fuses.
Name:	ImageUploadedByForest River Forums1472500607.688631.jpg
ID:	118749Click image for larger version
Name:	ImageUploadedByForest River Forums1472500622.661156.jpg
Name:	ImageUploadedByForest River Forums1472500650.991291.jpg
Roger64 is offline   Reply With Quote
2014, awning, led, light, power, solera
