Old 05-02-2019, 06:56 AM   #1
Awning plastic
The rear plastic cover for the awning guts on my 2016 Isata 24 seems to have departed.
Any idea for replacement source?
FFred is offline   Reply With Quote
Old 05-02-2019, 07:04 AM   #2
Awning Manufacturer.
TheWolfPaq82 is offline   Reply With Quote
Old 05-02-2019, 07:55 AM   #3
You'll need to know the awning manufacturer and the part number for the arm. The 2015 Solera's used the Dometic 8952002.400B (white) awning arms. You may be able to get specific parts directly from Dometic, though their web site seems to direct you to their dealers. If it's a Dometic, I'd give them a call anyway.
Note that the awning arm manufacturer and part numbers should be on your coach build sheet...
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 05-02-2019, 11:39 AM   #4
chroniekon's Avatar
I think our Isatas use Carefree Awnings. There is a sticky on the dynamax subforum that lists all of the vendors and their contact info.
This missing part has come up before in the past and I think I remember reading that they will send you a replacement for free.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 05-02-2019, 07:42 PM   #5
milkman55's Avatar
You have a dual stage Latitude awning by Carefree. You are probably missing part #9 per the diagram. You can find the full parts list on Carefree’s website and order directly from them.
https://www.e-carefree.com/ecarefree...r?productId=91
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
milkman55 is offline   Reply With Quote
awning
