Old 03-11-2016, 01:34 PM   #1
Back up monitor
My monitor for the back up camera sometimes will not get a picture but just flashes. Anybody had this problem and if so what was the solution?
T72par
t72par is offline   Reply With Quote
Old 03-13-2016, 06:36 AM   #2
Had the same issue
T72par
Recently, we have had the same problem with our RVS camera system. It would work fine for the first 5-10 minutes (I turn the rear camera on while driving - it helps me with situational awareness and when passing), but then the monitor would go blank and flash. Same things when triggered by the turn signals. I assume it's the same as what you are describing.
I talk to the tech rep at RVS. She was very helpful and we went through several troubleshooting steps. Her diagnosis was a failed/failing monitor. I bought a new one from them online along with the multiplexer, just in case it was that instead. Part number for monitor RVS-619N and multiplexer RVS-501N. Their website is here
Of course this happened one month out of the 12 month warranty...
KatanaPilot is offline   Reply With Quote
Old 03-13-2016, 11:36 AM   #3
CharSolera's Avatar
Thanks for the link, KatanaPilot. My monitor recently read 'no signal' when I started the RV. Tried all troubleshooting options, but it wouldn't work. The next trip, worked just fine! Mine is also just out of waranty.
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 03-13-2016, 01:00 PM   #4
Back up monitor
Thanks Kantana pilot, I have contacted them via email and they gave me a phone number to call. My warranty expired on 3/3/16. We hadn't had the motorhome out on a trip since October and of course didn't realize that there was a problem.
Thanks again.
Old 03-15-2016, 09:23 PM   #5
MNtraveler's Avatar
Check for loose wiring and loose grounding (which I guess is a sub-category of loose wiring...). Also corroded connections of course.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 04-22-2016, 02:59 PM   #6
Rear Camera - it is what it is
Now that I have used the camera in the daytime and night time for a while - and researched how it works - I no longer think it has a problem, it's just a long way from the roof to the ground at night, and the camera can only light up so much area with infra-red.
At night, as long as you don't have any 'light' at the rear of the RV, the camera should display a B/W image. As soon as any appreciable amount of light appears in the camera's field-of-view, you can see it flip to a Color image, and the new light source can improve the image greatly.
I was thinking about adding two super-powerful white LED's to the lower slope of the rear bumper - on either side, and wire them in to the backup wiring. I think they would give me a much better picture when backing up in the dark. HOWEVER, until I re-do the CURT CONTROLLER location, I'll hold off on that particular upgrade...
nusslejj is offline   Reply With Quote
Old 04-23-2016, 08:41 PM   #7
back up camera
Actually I am new to this site and actually have a question on the backup camera.
My question is that my back up camera comes on when I stick it in reverse. (I suppose that's what its suppose to do) However I would like to see my toad vehicle while towing it. Any ideas?
seadoogtx is offline   Reply With Quote
Old 04-24-2016, 06:54 AM   #8
Mikegjax's Avatar
Just push the on button.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
