Old 08-09-2016, 08:40 AM   #1
Bangs, chirps and whistling..Forester 2401r
We have taken a few trips now in our new 2016 Forester (purchased in June) and overall we love it, it's the perfect size and floor plan for the two of us and our dog. Learning how things work and getting more and more comfortable with everything the more we use it. But we have noticed some pretty annoying noises while driving. There is a loud banging noise directly behind the drivers seat in between the drivers seat and the slide out. You can put your hand on the wall behind the driver and feel something banging inside the wall while driving - any ideas what could be causing this? There is also a lot of wind noise in the cab area while driving, we need to put the radio on a pretty high volume to both hear the music and the nav directions to overcome the wind noise. We've checked all windows, gaskets, etc. Finally driving home from our trip this weekend, we seem to have developed a "chirping noise" from the area around the door/screen door. We weren't expecting a super quiet ride based on the fact we are driving a tiny home around behind us, but these three are somewhat worrisome since we want to catch any major issues now before they get worse. Any one else experienced any of these noises, would appreciate any help with fixes or suggestions.
Thanks in advance
Mike and Jani
mlbellanti is offline   Reply With Quote
Old 08-09-2016, 08:47 AM   #2
Flybob's Avatar
This is discussed in the link below.
Woah! Loud bang from left side!!!
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-09-2016, 12:31 PM   #3
2012 Solera
Link discusses air brake and air bag noises. Believe the OP has a Mercedes Benz Sprinter based vehicle. No air brakes or air bags on it.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-09-2016, 02:17 PM   #4
Loefflerh's Avatar
Maybe same problem I had when I tried to drive home from the dealership with a brand new Forester 2401W? I did not leave the dealers lot, it was so annoying! I left it there (it was late in the evening) and they got to work on it next day. They said it was actually an easy fix, couple of hours and now all noise is completely gone.
That is what the invoice said: (Warranty of course)
Cause:Pulled all plastics took for arise found metal from van cut out rubbing on metal cabover bracing
Correction:Bent metal from cab cut away up away from bracing took for a ride noise is gone then I put all plastics back together ok now
I cross my fingers that you find your problem!
Hans
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - ?
Loefflerh is offline   Reply With Quote
Old 08-10-2016, 01:29 PM   #5
Cab noise excessive
I too have a very noisy cab. MyDW has to shout for me to hear her at speeds above 55. At 65, it is awful. It doesn't seem to be wind noise coming from the door moldings and it is not localized. It seems to come from everywhere. It is just load. I've ridden in 18 wheelers and they are quieter! The dealer says what dealers always say, they are all like that. I would like to hear music but we can only hear it when driving slowly. I have no idea on how to fix this problem. I know this is not right.
Any ideas?
Jerry Robillard
2016 FR Forester 2401 R (2015 MBS)
UltraGuage Blue - love it!
Aspenmeadow is offline   Reply With Quote
Old 08-10-2016, 01:50 PM   #6
We stuff a pillow between bottom step and door, helps with chirping noise while driving. Have same problem with hearing radio, we just talk and enjoy the scenery. Can't help you with the slide other than there is always air noise at high speeds.
Karter is offline   Reply With Quote
Old 08-10-2016, 05:43 PM   #7
We have the same chirping with the screen door at the bottom of the side step. A pillow is a good idea. I used the fuzzy side of sticky Velcro strips and placed between the door and screen door. I thought it would help but the chirpy squeak continues.
I laugh every time I see the little Bluetooth microphone for using a cell phone with the Jensen unit. I have not bothered using because I know the caller wouldn't be able to hear me.
While driving I have thought about and wondered if removing the panels and installing dynamat would help quiet the road noise.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 08-10-2016, 09:59 PM   #8
dukeboone's Avatar
I've managed to identify most of my noises except for one in the overhead bed.
The glass top on the stove would rattle, fixed that with bungie cords.
The screen rattled quite a bit, mostly from the bottom panel that has a solid plate. Cut some high density 3/16" rubber into narrow strips and placed it around the perimeter of the plate towards the bottom of the door which has eliminated most of the noise from there, but not all.
I had a lot of noise from loose screws rolling around in the cabinet panels. I pulled the Jensen JWM6A head unit and remove 6 screws from the interior of that cabinet. Found a couple screws including the one missing from the 32" flat screen mount under the overhead bed mattress.
I still have a chirping noise over the passenger's head and it seems that it's likely some of the metal framing rubbing up against something. The noise is intermittent and not isolated to bumpy roads. I actually pulled all the trim off of the overhead bed (where the cab is cut out) and also removed the panel behind where the ladder is stored. Not surprisingly the craftsmanship of the items hidden behind these panels is rough at best, but I still wasn't able to access the issue without being more invasive so I put everything back together.
I too have to turn up the volume of the Jensen VX7020 while driving but it's really not that bad, it's just loud when I come to a stop. I suspect there could be some difference in the seal of the slide between the flush floor slide used in the S floorplan vs the Schwintek slide used on the R and W floorplans. From what I've read there's a larger gap on the exterior with the Schwintek slide, so maybe the other is better sealed when at highway speeds. I'm only familiar with mine after all...
I have however used the Bluetooth successfully, and the caller on the other end could hear me just fine. But if there's passengers in the motorhome it's a little obnoxious since the speakers need to be loud, just like the stereo in order for me to hear. I generally prefer to use my Bluetooth headset, then again most of my calls are business related since typically the family is with me and I'd just assume not take those calls anyway..
Cheers
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 08-14-2016, 02:54 PM   #9
HVrunner's Avatar
My 2015 2401R has a subwoofer under the dinette bench seat. On mine the subwoofer was not fastened in any way. It was just lying on the floor. I added a few screws and anchored it to the 1x2 framing of the bench seat. I'm not sure if this is the source of the noise on your rig but it's an easy fix. Click image for larger version
Name:	ImageUploadedByForest River Forums1471200806.587761.jpg
ID:	117239Click image for larger version
Name:	ImageUploadedByForest River Forums1471200850.675404.jpg
2015 Forester 2401R MBS
HVrunner is offline   Reply With Quote
Old 08-15-2016, 07:41 AM   #10
Loefflerh's Avatar
All those comments above about noise sound horrible to me and I am sure something can be done!
After my initial problem which was rectified by the dealer immediately I have.a quiet coach which is a joy to drive....
Hans
Retired military
forester
