I really like my group 31 AGM batteries. They are a tight install but will fit... 105 amp hrs each give me lots of reserve. I have solar, and over the 2 months we travelled through the southern US, I only ran the generator to jumpstart my MC chassis, as I had a loose coach to chassis battery connection that was arcing and causing low voltage messages to the ECU. So it decided it would start. But after firing up the gennie, the voltage overpowered the ECU (I guess) and it started. After tightening the lead at the chassis battery, and clearing the codes, everything ran like a clock.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
