Old 07-29-2016, 02:35 PM   #1
Big Foot Remote
My remote system for the stabilizers quit functioning. I'm not sure if the issue is in the transmitter or receiver. I changed batteries in the remote even though the remote appeared to function (one battery did test low), then attempted the reprogram process. However, the system would not complete the reprogramming cycle. I can operate the jacks manually at the control panel, but it's a pain not being able to eyeball it for level at a distance.
I guess I could test my remote on another similarly equipped rig, or use someone else's remote to test my receiver. I stopped at one RV dealer, but they didn't service Bigfoot. Just wondering if someone here has a better idea.
Mark, Susan and Barney the SheltiePoo
2014 Solera 24R
Wrangler Toad with NSA Ready Brake
barnbnb is offline   Reply With Quote
Old 07-29-2016, 04:04 PM   #2
GM
bclemens's Avatar
I always just put them down until I felt the coach move. They're not designed to level...but if you were trying to get it somewhat level from front to back...I use the highly scientific "bottle on the table technique"
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 07-29-2016, 10:47 PM   #3
Sorry if you misread. I'm not talking about getting it level. My remote does not work, period. The remote is not communicating with the receiver.
2014 Solera 24R
Old 07-30-2016, 12:39 AM   #4
GM
bclemens's Avatar
You said you could manually lower at the control panel correct?
Old 07-30-2016, 12:59 PM   #5
Yes, the control buttons on the receiver will operate the jacks. The receiver appears to recognize the remote when I perform both the "sync" and "re-program" functions, but the jacks do not function via the remote.
So....one of the components is malfunctioning. I'm just trying to figure out how to determine if the problem is in the remote or the receiver.
2014 Solera 24R
