Old 01-28-2018, 10:56 AM   #1
Rich.M's Avatar
Bigfoot stabilizer hidden fuse
This may have been discussed already but today's project is to add a manual switch to the Bigfoot stabilizers to stop them from remotely activating in crowded parks. I traced the wires under our slide out rear bed on our 24R and found this hidden fuse. It is on the red wire to the manual controls. Probably the wire I want to add a switch. Add this to your mental list of hidden fuses in these coaches. Happy travels
ID:	161072   Click image for larger version
ID:	161073   Click image for larger version
Rich.M is offline   Reply With Quote
Old 01-28-2018, 04:54 PM   #2
I put a free hanging rocker switch (on very short wires) right next to the manual controls in the rear storage compartment. Seemed like the handiest spot, though I have been known to leave it on when it really should be off!
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 01-28-2018, 06:30 PM   #3
Rich.M's Avatar
I may put in 2 switches in a 3 way set up. The back of the manual control is visible in that space. It will be easy to add a a switch next to it and a senond switch at the foot of the bed inside in case I forget to turn the jacks off and they activate at night. Then I won't need to go out in my pjs to flip the switch.
2015 Solera 24r
2017 Jeep Wrangler
Old 02-04-2018, 09:04 AM   #4
JoeSteiner's Avatar
As I recall, my Bigfoot stabilizers would turn on and make noise from time to time. I disconnected the remote control antenna wire and that seemed to fix it. I never use the remote.
JoeSteiner is offline   Reply With Quote
fuse
