Old 09-05-2018, 04:29 PM   #1
Bimetallic corrosion?
These bumps appeared between our door and kitchen window. Is this something anyone else has seen? 3 months out of warranty will FR fix this?
Automatic_11 is offline   Reply With Quote
Old 09-05-2018, 07:17 PM   #2
AudiDudi's Avatar
Have you opened up one of the "bumps" to see what it actually is?
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is online now   Reply With Quote
Old 09-05-2018, 07:18 PM   #3
CZNEDY's Avatar
That right there is a sign of water infiltration. Those little bumps are from the glue behind the paper getting wet and expanding.
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 09-05-2018, 07:58 PM   #4
No I havenít. I donít really want to cut the wall covering open. May not have much choice.
Old 09-05-2018, 08:02 PM   #5
I park it inside my barn out of the weather. And haven’t had any signs of water damage anywhere else.
Old 09-05-2018, 08:04 PM   #6
CZNEDY's Avatar
Check around the kitchen window and the door for leaks. Sorry to say but it is definitely water. Also, check the roof seals. If you pick at them, you'll just wreck the wallpaper.
Old 09-05-2018, 08:06 PM   #7
We had a Holiday Rambler MH that the fuel gauge wire came off, and I knew nothing about something called " Galvanic corrosion ", Until I took it in to the shop, they found parts of the door, side of the MH starting to rust even the aluminum was getting corroded. Mine appeared like yours under the decals first..
So might check to see if any loose grounds or wires or if any instrumentation has stopped working recently.
Craigrrr is offline   Reply With Quote
Old 09-06-2018, 08:47 PM   #8
CZNEDY's Avatar
Here is a picture of the back wall in our flagstaff fifth wheel from a few years ago. Water was getting in through the windowClick image for larger version
Old 09-06-2018, 09:14 PM   #9
I received a reply from FR warranty mgr today saying it looked like the window seal was allowing water in. They would honor and fix it under warranty! They’ll also repair internal panel and wall covering.Thanks for the replies folks!
Old 09-07-2018, 05:09 AM   #10
CZNEDY's Avatar
Anytime.
