Old 08-07-2018, 04:29 PM   #1
Black /Grey tank vent
We have a 2017 2400WS MBS I noticed only one tank vent on the roof. I assumed that they combined the two tanks into one vent, but after getting random tank odors while traveling is making me think twice. Can someone confirm the number of vents for the same make/ model / year?
thanks in advance!
murphytm2001 is offline   Reply With Quote
Old 08-07-2018, 10:57 PM   #2
2017 Sunseeker 2400w
We only have one. I believe it was called the cyclone vent or something similar.
gmccullers is offline   Reply With Quote
Old 08-08-2018, 06:09 AM   #3
Thanks for the reply
Tim
Old 08-08-2018, 10:42 AM   #4
Head Rambler
They usually combine the vents. The black tank will be a 'dry stack' and the grey tank(s) will be 'wet stacks'. Then you'll also have air admittance valves at the sinks.
The air admittance valves are likely where the odors are coming from. They tend to stick open sometimes.
Gotta go campin!
Old 09-21-2018, 09:28 AM   #5
I put a solar power fan on the exhaust stack. Fixed smell.
hstroupe is offline   Reply With Quote
Old 09-22-2018, 07:49 AM   #6
Depending on the brand of toilet installed , there will be a hole in the bowl in the rear fairly high up.
This is for overflow prevention , should the fill valve leak the dribble of water is drained there
These are used with a hose behind as an air trap ,bent into a U otherwise it would be a straight shot for black fumes into the coach.
Every so often it is needed to fill the bowl to this drain , but not open the flush.
The shower hand held does a good filling job, before the next tank dump.
Might be worth a test fill?
FFred is offline   Reply With Quote
black, tank, vent
