Old 05-30-2019, 05:30 AM   #1
Buying a new RV any suggestions on walk around
Hi first time posting and first time buyer.
Iím buying a new forest river forester MBS 2401W.
How thorough of walk around do I need to do and any suggestion on anything particular I should be looking for.
FYI itís new but itís a 2018 year, and itís been sitting on the lot since last year.
Ralph
hawaiirafael is offline   Reply With Quote
Old 05-30-2019, 05:56 AM   #2
I would plan on spending a day or more camping at the RV dealer.
There are many systems to learn , and to make sure all operate properly.
If its on board , use it!
Awnings , generator air cond, stove , microwave and hot water heater as a tiny start.
Do not drive off till EVERYTHING works !!!!
FFred is offline   Reply With Quote
Old 05-30-2019, 06:59 AM   #3
Thanks Iíll do that 👍🏼
Old 05-30-2019, 07:14 AM   #4
If you are not clueless a PDI should take hours depending on the complexity of the unit. You must walk away knowing how stuff works that was DEMONSTRATIVED for you.
The lists are available.
Your expectation is everything works. No need to return to the dealer, ever!
No, we will fix it after your trip.
No fixie no check. Be prepared to come back later. Not what the dealer wants.
You could hire help or bring a friend.
tomkatb is offline   Reply With Quote
Old 05-30-2019, 07:24 AM   #5
Thanks for your reply
Great advice Iíll take as much time as I need and hope they wonít give me any trouble about staying over a night.
Thanks sincerely
Ralph
Old 05-30-2019, 07:44 AM   #6
dcheatwood's Avatar
Check everything. Slides, Jack's, fridge and water heater on lp and electric. Stove, oven, a/c's, water pump, jacks, landing gear, microwave, tv, stereo, fans, etc. Check toilet for flushing, shower and sinks for flow. Make note of everyting that isn't right and don't take it until it is.
2018 Forester 3011 DS
Old 05-30-2019, 12:18 PM   #7
MilCop4523's Avatar
list.
seal check
tire check - make sure you get them to roll the trailer .5 of a wheel turn as we didn't in 2016 and found tires scrubbed off to the cords a couple miles down the road when we stopped for the night)
Cable and Satellite connections our 2018 had neither one working and friends of ours found the living area was wired to the bedroom
FW pump actually pulls water from the FW tank our 2019 didn't and it took a couple hours to trace the cause.
radio stereo works
Television if included does it work - will it pick up any free to air channels as we had one trailer in 2012 which had the antenna N/S.
slide out operations in and out.
door and compartment locks - our 2019 has 2 bad locks which the keys will not turn
sewer and gray water pulls handles free or binding
toilet - will it flush water and hold water at the seal
microwave - take a bag of microwave popcorn and pop it while there
make sure the round glass plate is present as well (our 19 was missing it)
fridge and freezer cold?
decals not peeling - yet?
AC unit
between other posters and this we should have you covered...
Happy camping
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 05-30-2019, 12:36 PM   #8
That was awesome this forum is so cool glad Iím a part of the fam
Hope to return the favor in the future
Ralph
Old 05-30-2019, 12:54 PM   #9
Look for....
... loose hardware. Everywhere. We had a pocket door pretty much fall off during our first camping trip in our brand new unit because someone at the factory didn't tighten the screws that hold the bracket that the door slides on. I "manufactured" a six foot long philips screwdriver to get at the screws because the only other option would have been to cut a hole in the wall. If it hadn't been for the fact that there are two doors to the master bedroom my DW would have been trapped in there for quite awhile. There were quite a few other loose screws (and a couple of plumbing fixtures) as well.
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 05-30-2019, 12:55 PM   #10
BillyBass's Avatar
Being new ask a lot of questions and take notes
2019 Flagstaff 26 RBWS
2005 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
