Can anyone explain this in detail ...
Threads have talked all around this question, but I have never read anything that provides all the answers.
Q: How do the coach and chassis batteries charge when parked, and if there is more-than-one way to charge them, what is the best way ?
1. If the 0/1 disconnect is 0, are the coach batteries completely isolated from the chassis battery ?
2. When the coach is plugged into shore-power, does the chassis battery also charge when 0/1 disconnect is 1 ?
3. If the chassis battery is on a charger, do the coach batteries charge when 0/1 disconnect is 1 ?
4. If the 0/1 disconnect is 0 and the coach is plugged into shore-power, will any batteries charge ?
5. Can you attach a charger to the chassis battery while the coach is plugged into shore power ?
6. If the coach is on a separate charger (not shore-power), does the chassis battery charge ?
7. If the chassis battery charges off the coach when the coach is connected to shore-power, will the coach charger boil the chassis battery ? If so, can you / should you connect a smart charger to the chassis battery separately ?
8. When winterizing your RV, do you plug the coach into shorepower, do you attach a charger to the chassis battery, do you attach a charger to the coach and another to the chassis and not plug into shore power ?
9. When driving the RV, does the chassis charge the house batteries ?
Lots of questions - and I may not have thought of them all. We will all benefit from good answers !
