Old 07-13-2017, 04:09 PM   #1
787
787's Avatar
Can I get on the Roof 2400R
I have been RVing for years. My Forest River 2400R is the first RV I have owned without a ladder. I have always assumed if you had a ladder on the back you can go on the roof. I was wondering if I can walk safely on the roof.
787 is offline   Reply With Quote
Old 07-13-2017, 04:12 PM   #2
Rich.M's Avatar
I go on mine every 6 months to clean the solar panels and skylights, check and repair dicor seems. No problems but it may depend on your weight
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 07-13-2017, 04:28 PM   #3
The only reason it doesn't have a ladder is that the rear slideout is in the way (though at least one owner installed a narrow one next to the slideout...)
Anyway, the other models, essentially identical except for the floorplan, all have ladders.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 07-15-2017, 12:00 AM   #4
I was told during PDI of our 2400W that weight limit on roof is 300 lbs .. I agree with reply above .. no ladder due to rear slide
slavka is offline   Reply With Quote
Old 07-15-2017, 11:55 AM   #5
Mikegjax's Avatar
Was on the roof of my 24R today doing some cleaning. Not a problem at all.
Been up there plenty of times in the last 4 years. No ladder is strictly a space issue.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 07-15-2017, 04:18 PM   #6
Unless the slide out is in the middle of the back of the motor home there is no way you can install a ladder. Our 2500TS Sun Seeker has the bed room slide out back and there was lots of room on the back of the unit to the side of the slide to do the ladder install. I just installed one this past week and just prior to that got the part number from Forest River and the schematic so I knew I had the correct ladder.
An easy install in about 2 - 3 hours.
Brandon2
2014 2500TS
Sun Seeker
brandon 2 is offline   Reply With Quote
Old 07-16-2017, 06:59 PM   #7
Senior
There are collapsible ladders available that you can use to get on the roof instead of a fixed ladder. The roof is designed to support your weight.
sailski is offline   Reply With Quote
roo, roof
