Old 03-04-2017, 06:11 PM   #41
Glad it worked for you
Originally Posted by backdoctor View Post
I bought corrosionX from Grainger's in Jacksonville before I headed home. I gave all the exposed electrical cables nnections on the back of the battery management centre a blast. And since I was having a little hesitation starting the Genny, I sprayed the solenoid connections there too. They were corroded, and the problem with starting disappeared. Amazing stuff. I've never read such positive reviews on Amazon! Like they say, this stuff rocks! Thanks katana pilot.
It is a great family of products. I sprayed the entire underside of my son's Tacoma that had been through North Dakota, Maine and Minnesota winters. The Corrosion X stopped the rust and protected the truck for about a year. It's due again. Should do well for you in the Great White North.
We also use it as a corrosion block on the inside of aluminum airplane structures. It seeps into every nook and cranny and does a great job. We use a specialized sprayer with long nozzles for the planes - but the aerosol cans work well for most applications.
KatanaPilot is offline   Reply With Quote
charging
