Old 11-05-2018, 11:10 AM   #1
Chassis battery terminal corrosion
We had a no start situation on the weekend. Seemed like a dead battery, and when I fired up the Genny and patched it through the coach to Chassis circuit (I installed a switch to override the BCC logic circuit) it started right up. Over the remainder of the weekend this was the protocol for starting.
When we arrived home I removed the cover for the chassis battery in the cab, the positive terminal was so corroded, it wouldn't conduct enough current to start the engine. Click image for larger version
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 11-05-2018, 11:15 AM   #2
So I disassembled the various pieces. The terminal connector is copper, this the blue colour, the buss connector is brass, this the brown colour. Inside the buss box, the corrosion was so thick it was pushing the box apart!
The connecting but we're so corroded they lost their hex shape and I had to use vice grips to get them off!
Any idea why so much corrosion in a sealed compartment, with an AGM battery?
Eric Jackson
2015 Solera 24R
Old 11-05-2018, 12:50 PM   #3
Don’t know what could cause that. I rushed out to check mine and it’s clean. Weird
Rogerbruchay is offline   Reply With Quote
battery
