Old 03-02-2019, 04:58 PM   #1
WILLMCC's Avatar
Exclamation Coach Batteries MBS 2401R
Has anyone tried to replace the coach battery in the left side under the driver's seat. Battery ran down and I want to take it out and charge it before I can see if it needs to be replaced. Did not discount the long term storage connector near the gas pedal before it drained the battery. Is this a simple process, there are quite a few connections to the battery.
WILLMCC is offline   Reply With Quote
Old 03-02-2019, 06:26 PM   #2
Can't help you with the battery removal, but would like to clear up a common misconception about the battery ground disconnect located near the accelerator pedal on the Sprinter -
Disconnecting this quick disconnect will NOT disconnect the chassis battery from the chassis. There is an alternate path to ground provided by the coach wiring added by FR.
There is an easy way to prove this - go ahead and disconnect the quick disconnect. Open the door and watch the instrument panel come alive. The chassis is still powered through the chassis battery.
The only way to positively disconnect the chassis battery is to access it directly and disconnect the ground wires connected to the battery terminal.
KatanaPilot is offline   Reply With Quote
Old 03-02-2019, 06:36 PM   #3
AudiDudi's Avatar
Originally Posted by KatanaPilot View Post
<snip>
Disconnecting this quick disconnect will NOT disconnect the chassis battery from the chassis. There is an alternate path to ground provided by the coach wiring added by FR.<snip>.
Good to know. Thanks! I don't use it anyway and the battery stays charged for a month with no issue.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 03-03-2019, 05:56 AM   #4
Mikegjax's Avatar
There are connections under the hood for jumping/charging the chassis battery.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
batteries
