Originally Posted by Hexnut
The batteries under the steps have a hold-down strap across the top of the batteries and disappears down each side. Can someone enlighten me on how to loosen/remove the strap for battery maintenance? I suspect there is an attachment on the outside of the housing, but the foam spray may have it covered.
Nope. On the very far right side of the battery, as the tether descends into the abyss, there is a closure. It's an alligator type, if I recall correctly, and is a real challenge to get undone. Then you can take out the right battery, slide the left battery over and remove the remaining tether. Getting it back together is less of a struggle...
