Old 12-10-2015, 01:38 PM   #1
Cold Weather use
I am looking at the Forrester MBS2401w...I go on elk hunting trips in the rockies in the mid to late fall where temps frequently get below freezing...and am concerned how weatherproof/coldproof the tanks and lines are? Any help? The online brochures etc are pretty weak about how protected they are.
LarryAuTrain is offline   Reply With Quote
Old 12-10-2015, 02:26 PM   #2
I know several people who use their RVs for deer hunting in northern Minnesota. They use the grey/blackwater tanks for waste but usually have their freshwater lines winterized by that time. Usually bring along jugs of water.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 12-10-2015, 03:44 PM   #3
I guess I would expect better if I was spending this much money...I would want full use of my water tank, shower, kithcen water etc as well as waste tanks...even if I had to add some solar panels, an inverter, extra battery, and then install light bulbs or low draw heat source to keep it all warm...afraid the Forrester has outside exposed tanks etc
Old 12-10-2015, 04:08 PM   #4
KenHwy61's Avatar
You can do things to make you camper more below freezing 32F (not below 0F) tolerant. First of all you need an enclosed underbelly to begin with. It is fairly easy to keep things warm with an electrical supply by using space heaters, heat tape and tank heaters. With only batteries and propane you will limit yourself to how long your batteries will run the furnace.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
