Originally Posted by aspengirl
Thank you Dave. When we left the RV park, the light wasn't on, and the generator wasn't running. later we stopped for an errand and when I went into the coach noticed the light was on. The last time we ran the generator was a couple weeks ago to exercise it. We referred to the owners manual and tried to retrieve the error code but the light didn't blink at all.
Bummer. Well, here's a link to an older thread on irv2.com which talks about a very similar issue:
http://www.irv2.com/forums/f258/help...ue-203869.html
Note the resolution which turned out to be a problem in the wiring harness between the generator itself and the interior control panel. As that person did, you might be able to pull that connector to see if the generator will work when operated by the controls on the generator itself.
That thread also referenced another thread...which I did not follow but which might have additional info.
Note that I did a google search:
onan generator indicator light stays on
which turned up a variety of hits.
Good luck.
Dave
