Old 12-22-2023, 07:50 AM   #301
Resistors - Placement-wireing
I created a heat sink board (see photo) and test wired in the resistor for left turn.
Still have hyper flash?
Resistors were wired in-line upstream of Hopkins Controller.
Question- does the heat sink board need to be grounded? Is that the likely problem?
Friendly Tex is offline   Reply With Quote
Old 12-22-2023, 09:30 AM   #302
2012 Solera
Resistors need to be wired from incoming wire to ground - not “inline”. Resistors need to simulate a bulb to load the incoming line.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 12-22-2023, 09:42 AM   #303
I agree
I agree.
Larry
Larry-NC is offline   Reply With Quote
Old 12-22-2023, 10:01 AM   #304
Wiring Resistors
Does that mean there is a T or Y in the wiring?
IE Line In to resistor and to controller
Resistor out to ground?
Old 12-22-2023, 10:22 AM   #305
T
A T. Resistor out to ground.
Larry
Old 12-22-2023, 10:49 AM   #306
Old 02-12-2024, 03:00 PM   #307
2012 Solera 24 S Replace tailight Circuit Board with Hopkins
All, Thanks for your help. Job is complete and works just fine.
Didn't make sense to go back to old circuit board for almost $500 plus wait for it to be made. Forest River has changed the deisgn twice since then so I updated to the most current approach and saved about $380.
Installed a Hopkins 21146375 Pulse width modulator for $81.00, A HELLA relay 007794301 $10.00, plus pigtail $21.00 to power the backup lights, and two resistors uxcell 2pcs 50W 10 ohm Load Resistor, one for left and right turn signals for $8.00.
I also installed a fuse block $18. and fused each light so that if one blows, the fuse goes and not the circuit board (now pulse width modulator) like before.
It is a tight fit in the orginal space behind the facia board at the back of the shelf where your extenal power cord is stowed. Here are a few pics of install.
ID:	296941   Click image for larger version
ID:	296942   Click image for larger version
Old 02-12-2024, 03:21 PM   #308
Wiring Info
I made this chart to keep track of Wiring.
Column 1 original wiring into circut board,
Column 2 -The coresponding input to Hopkins controller colors,
Column 3 - The output from the Hopkins to my fuse panel,
Column 4 - The wiring for the backup light relay (Hella),
Column 5 - the output from fuse box to tail lights,
No guarantee your colors will match my Solera 2012 24S wiring. Good luck.
controller, light
