2012 Solera 24 S Replace tailight Circuit Board with Hopkins
All, Thanks for your help. Job is complete and works just fine.
Didn't make sense to go back to old circuit board for almost $500 plus wait for it to be made. Forest River has changed the deisgn twice since then so I updated to the most current approach and saved about $380.
Installed a Hopkins 21146375 Pulse width modulator for $81.00, A HELLA relay 007794301 $10.00, plus pigtail $21.00 to power the backup lights, and two resistors uxcell 2pcs 50W 10 ohm Load Resistor, one for left and right turn signals for $8.00.
I also installed a fuse block $18. and fused each light so that if one blows, the fuse goes and not the circuit board (now pulse width modulator) like before.
It is a tight fit in the orginal space behind the facia board at the back of the shelf where your extenal power cord is stowed. Here are a few pics of install.
