04-04-2016, 09:03 AM
#21
My friend who just picked his up straight from the factory very recently - was installed in exact same place as mine / same method.
2016 Sunseeker W MBS
04-04-2016, 01:34 PM
#22
This would be a great opportunity for FR to step up, acknowledge there is an issue, develop a fix (hopefully one that can be retrofitted) and provide that information to us.
For me, I like the idea of the pvc box, although in the interest of simplicity, I may just install weather pack connectors (I have some and they are waterproof) and spray the controller with Corrosion X.
04-07-2016, 08:17 AM
#23
My 2014 24R does not have the CURT Controller. It has a fairly large circuit board located to the rear of the fresh water tank near the pump.
With the key set to on or position one my rear left turn signal only lights the center LED in both of the left fixtures . If I start the engine the left rear stops flashing and the remaining LEDs are very dim. Jumped power from the right light and all works well.
Has anyone replaced the circuit board with a CURT controller and if so did you replace the entire circuit board. Looks like the board does other things than just the tail and trailer lights.
Any info. would be appreciated.
2014 Solera 24R
USN Retired
04-07-2016, 09:03 AM
#24
Problem solved! Found a partially blown10 amp fuse, replaced same and all is well. When I did the fuse continuity check it showed the fuse was good. On closer visual inspection I could see a slight discoloration of the strip. Apparently the fuse was producing high resistance with power demand.
Much relieved. Hope this info. may help others.
2014 Solera 24R
USN Retired
04-07-2016, 11:42 AM
#25
2012 Solera
Mike -Glad to hear you got it solved. Lots of discussion of the earlier (pre-Curt) module you and I have:
http://www.forestriverforums.com/for...e-15530-2.html
Someone came up with a slick "emergency fix" to get tail and running lights (if not towing a toad or trailer) - the most reported failure mode with the "old" module. He got a trailer plug and connected the power terminal to the running lights terminal (with a fuse). Vehicle running lights "on" when plugged in; have to unplug it to turn them off. I now carry a plug with me "just in case".
JLeising
2012 Solera "S"
Calif SF Bay Area
04-07-2016, 12:57 PM
#26
Weatherproofing the Curt Controller ???
Has anyone made changes in an effort to weatherproof the controller and the various connections? My controller (model # S0601U-R1) looks to be pretty well sealed, but I'm sure it's not completely waterproof. I was thinking about putting it into a waterproof box, but there's very little space available in it's current location. The controller is about 2-1/4 by 3-3/4 by a bit less than an inch high (not counting the wires coming out of both ends). It's mounted on a metal plate with perhaps an extra inch in the height direction. I think it would be very difficult to find a box that would be big enough to hold the controller, but small enough to fit in the space.
I'm thinking of just covering all of the cracks and wire holes with some sort of sealant - maybe a caulk or a foam.
Has anyone found a box that fits? Or tried the sealant approach?
Dave
2015 Solera 24R
2014 Mercedes Chassis
04-07-2016, 12:59 PM
#27
Thanks for the reminder on the emergency fix. I talked to Travis at FR today and he says the old stile modules are still available from FR, but must be ordered through a dealer. He also said you can't just replace the old with the new Curt due to a different wiring harness that is now used.
Hopefully this one will hold up for awhile.
2014 Solera 24R
USN Retired
04-07-2016, 02:04 PM
#28
I was thinking about this box. Homedepot locally sells it for about the same price. You would have to cut open both sides a bit for the wires, then use a sealant.
Robot Check
04-07-2016, 03:36 PM
#29
Robot Check
I looked at that box - looks like the box is pretty waterproof - and thought about it some more. I've decided to skip the box and just try sealing things with a non-corrosive sealant. It seems like there are two problems with the box...first, I'm not sure it'll fit in the space available...and second, even if it does, you still have to seal where the wires go through the box.
I think I can apply a sealant over the line between the two halves of the Curt box and around each of the wire entry points...it should keep things dry...I hope.
Dave
2015 Solera 24R
04-07-2016, 06:18 PM
#30
Dave. The number on the label (S0601U-R1) is simply a label that Curt uses, and has no significance with respect to the model of the taillight controller module. I learned this first by googling the number and getting junk, then searching Curt's website and getting nothing, and finally calling their tech support and speaking to a very fine man named "John" who explained they had no unit at that designation. It was a label name... He couldn't identify what my controller was at that time, although the following day he followed up with me to indicate that forest river outsources the connections. I was very impressed that he had gone to that much trouble! And now you know...the rest of the story! Grin
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
04-07-2016, 06:19 PM
#31
The Curt unit number, as per Dukeboone is 56146.
Eric Jackson
2015 Solera 24R
04-08-2016, 06:45 AM
#32
I think I can apply a sealant over the line between the two halves of the Curt box and around each of the wire entry points...it should keep things dry...I hope.Dave
Dave - what about extending the entire panel to the inside rear storage compartment ? I'm thinking there are maybe 10-12 wires you would have to extend. Install a rubber grommet into the bottom of the rear storage compartment tray - pass wires through in a protective sheathing and screw the same exact plate to the wall - facing the wall for protection. I think that is where FR should have put it - INSIDE THE RV.
I'll be going up to our 2015 24R this weekend and will scope it out to get an idea of the level of work and whether it makes any sense.
Jeff
04-08-2016, 06:56 AM
#33
Jeff[/QUOTE]
Jeff, on my 2014 24R the light controller (not CURT) is located out of the elements in the water tank/pump compartment just to the rear of the pump. Is your controller located in a different location? Just curious.
2014 Solera 24R
USN Retired
04-08-2016, 08:54 AM
#34
Yes - the 'new' FR design using the CURT controller mounts it behind the rear bumper on the drivers side. It is exposed to the elements, and can easily get all the road debris and liquids the tires can throw up there. When FR decided to replace the controller with the CURT, they should have used the existing location - which I think is far better than outside, behind the bumper and in the path of road debris and water. The plate the CURT is mounted to does not shield it very well. This is a surprisingly bad design and I hope FR will correct it for new purchases.
In the meantime, we are all brainstorming the best solution. I'm leaning toward moving the CURT inside. A mini soldering torch, heat-shrink tubing, 4-5 colors of wire, and maybe 1-2 hours of labor should get it done.
I'll know more what I want to do this weekend.
Jeff
04-08-2016, 02:24 PM
#35
Jeff
Yeah, they probably should have put it inside. I think it's a bit of work to move it, but it could be done. The connections to my controller go through two Deutsch plugs / sockets, a six pin version on one side and a four pin version on the other. These connectors are available here:
Deutsch DT Series Connectors
One interesting possibility is that they sell the connectors pre-wired with arbitrarily long pig tails. You could buy two more plugs and two more sockets and get one side of each wired up with appropriately long wires, Run the wires to your desired location, attach the previously unconnected end of the wires to the appropriate connector, and just plug the controller in at it's new location. They'll even color coordinate the wires! (They're a bit pricey - the six pin connector goes for about $60 with 8 foot wires...)
Anyway, I'm still on the track of adding more sealant around the box. The box certainly appears to be pretty well sealed to begin with - I've got it off the motorhome and close inspection shows no gaps or openings. I suspect that the two halves of the case are glued together - no obvious way to get it apart.
Ah well.
Dave
2015 Solera 24R
04-08-2016, 02:36 PM
#36
I think the combination of Jeff's and Dave's ideas is the best. Keeps the factory connectors intact, does not involve splicing and gets the "waterproof" Curt controller out of the elements.
Great brainstorming guys. I'd be working in this today, but I'm traveling down under for a few weeks. Most of the "caravans" down here are right hand drive Sprinter based. Very few designs with slide outs, but they do have a smaller shell placed on the chassis.
04-08-2016, 03:19 PM
#37
Dave - that is a great find. Extending both with a pre-built 4-ping and 6-pin extension is a very good solution. I would bet you only need 3' or 4', which may cut the cost a bit.
04-21-2016, 11:40 AM
#38
Remounting Curt controller
2016 Forester 2401R MBS
Trekker Low Profile Cap
04-21-2016, 11:54 AM
#39
It is a shame the factory doesn't take the trouble to do this but having read here that they were sold a bill of goods by the curt salesman, it kind of explaines why it is how it is. You sound like a lot on the forum, see something can be changed/fixed do it!
Sent from my DROID4 using Tapatalk
04-21-2016, 03:42 PM
#40
Great work WrightWood !
You really improved on the FR solution, and also did a great job documenting it with narrative and pictures !
I think FR should have laughed and said "try again" when the current wiring MESS was presented to them as a solution to the previous wiring design (which btw I hear was located inside the coach). I wouldn't let FR off the hook because someone 'else' designed it. It is after-all, their product and ultimately their decision how to do things.
I have one question now that I see the details of what we have to work with - since you had about 1' of slack in the wiring, what do you think about drilling a hole into the storage pod, and moving the components 'inside', and somehow protecting them within the storage area as opposed to a waterproof box on the 'greasy side' of the rv ? You would be able to comment better than anyone else (including FR).
Again, Great Job !
