Old 06-28-2019, 08:40 PM   #1
Dash display ?
2015 FR Solera. An my dash display, when starting, I see a symbol and wrench followed by 7d.
I have been unable to locate information on this code. I'm sure it is a maintenance issue.
Larry99
Larry99 is offline   Reply With Quote
Old 06-29-2019, 05:10 AM   #2
Mikegjax's Avatar
Larry99
7 days passed a maintenance issue. Probably oil change or A/B check. Reset video available on YouTube.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-29-2019, 07:30 AM   #3
Thanks. Since this is a new to me coach and the selling dealer didn't provide maintenance records I'm in the dark.
Larry K
Old 06-29-2019, 08:15 AM   #4
Mikegjax's Avatar
You can find much of the info. in the operator's manual. If you don't have the manual, it can be downloaded from MB support. I do recommend YouTube for the reset procedure.
2014 Solera 24R
USN Retired
Old 06-29-2019, 09:22 AM   #5
Mikegjax's Avatar
Larry99
Here is the reset procedure for no steering wheel buttons.
With steering wheel buttons.
2014 Solera 24R
USN Retired
Old 06-29-2019, 03:46 PM   #6
Thanks all. I finally have a picture https://photos.app.goo.gl/RcZpdy9Eaue1n5Rz5
From looking the owners guides I am unable to find a similar error.
Larry K
Old 06-29-2019, 06:30 PM   #7
Mikegjax's Avatar
The 8d indicates you have exceeded a maintenance interval by 8 days . Tomorrow it will be 9d unless you do the correct reset procedure. If your oil change has passed it's due date by calendar days, you are reminded it is time for an oil change or some other scheduled maintenance. It may be as simple as someone did not complete the reset the last time the RV was serviced.
2014 Solera 24R
USN Retired
Old 06-29-2019, 07:06 PM   #8
Thanks for your patience. I was confused because I was expecting an oil can as an icon.
The reset is done. The selling dealer was to have changed the oil and filter. I will check with them Monday
Thanks again.
Larry K
Old 06-30-2019, 12:04 PM   #9
AudiDudi's Avatar
As I recall, the 51 in the reset is if you are using 229.51 rated oil. In my 2016 Prism, I use 229.52 rated oil and I choose 52 on the reset screen to get the 20k mile interval.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is online now   Reply With Quote
Old 07-01-2019, 01:14 PM   #10
Thanks again.
Odds are that the dealer used the wrong oil, if they did indeed change it. The wrong oil will void your warranty on the emission systems...
If they changed it, you need to verify that the correct oil was used. And that's not brand or weight, but which specifications the oil meets. These rigs require a special low ash formulation that is not commonly found on the shelf of most dealers or retailers.
Mark & Susan
2016 Forester MBS 2401WS
Wrangler Toad
barnbnb is offline   Reply With Quote
