Old 08-07-2015, 11:22 AM   #11
Buy it at Wal-mart ! Saving 50 or sixty cents on 2 1/2 gallons does'nt make much sense to me !
wanderingbob is offline   Reply With Quote
Old 08-07-2015, 11:32 AM   #12
2012 Solera
DEF consumption rate
Originally Posted by Beach Bums View Post
After about our first 1200 miles, I decided it was time to get some DEF (I may have missed it, but could not find the consumption rate of DEF). We purchased it at a truck stop and the set up is how you explained...opposite side of the fill.... The hose was plenty long to reach. At 1200 miles....we added ~.8 of a gallon... Still not clear on the consumption rate.
I believe our 2012 "S" uses about one gallon every 2000 +\- miles. I have them fill at the 10,000 mile oil change. I add a gallon 3000 miles later, then another gallon each 2000 miles until the next service. Avoids both DEF overflow when filling and the dreaded DEF warning light. I use one gallon jugs (refill at home from 2.5 gallon jugs; use the fill tube from the 2.5 gallon jug - fits the gallon jug perfectly). At one gallon per 2000 miles, cost is not significant.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-07-2015, 11:32 AM   #13
AquaMan's Avatar
I'm not certain on the consumption rate, because it does vary depending on towing conditions, but without towing, I think I get right around 1000 miles to a gallon. I just run it until I have about 200 miles left then add.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-07-2015, 12:34 PM   #14
mud yapster's Avatar
I use walmart for fuel also when I'm close to one. I still think if I'm required to put it in my truck they should be required to have a pump with it. I don't care what it cost them to retrofit their pumps. They didn't care what extra it cost me to retrofit my truck.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-07-2015, 12:48 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
I sometimes use a gallon of windshield washer per 1,000 miles, so why doesn't Walmart have pumps to dispense it?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-07-2015, 01:50 PM   #16
CharSolera's Avatar
Thank you, JLeising. Pouring a gallon of DEF is doable, where I'd be challenged to pour from the 2.5 gallon box. Beach Bum, it's good to know the hose on the truck stop pump reaches to the far side of the rig. Thanks to others for their speedy suggestions!
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 08-07-2015, 02:10 PM   #17
A suggestion, when you are buying DEF from Walmart unscrew the cap, check the seal. If the seal is broken it was drained and returned to the store filled with water.
Yep, that happened to a friend, one container full of water. He caught it right after his purchase, just check.
gary ca is offline   Reply With Quote
Old 08-07-2015, 02:19 PM   #18
But your not required to use it by law like DEF. If the DEF runs out in you truck you can't go anywhere. When you washer fluid runs out your vehicle doesn't shut down does it.
Old 08-07-2015, 06:25 PM   #19
elind's Avatar
It's no more an effort to top off DEF or window washer in between oil changed. I just prefer to do it at my pace without a line behind me waiting.
2014 Wildcat 327ck
Old 08-07-2015, 06:57 PM   #20
RedLdr1's Avatar
While I was checking on our "W" at the M-B dealer I asked the Sprinter Service Manager about DEF consumption. He answer was to plan on using approximately 1 gallon per 1,000 miles.
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
