Old 04-23-2018, 09:04 PM   #1
AudiDudi's Avatar
DEF usage
My DEF indicator was down to 3 bars after 5650 miles (8700 miles total on the rig) and 11 months so I decided to add 2.5 gals. That brought the DEF indicator up to 8 bars and is a little over 2200 miles per gallon.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 04-23-2018, 09:11 PM   #2
Good for you
Jack
jaherbst is offline   Reply With Quote
Old 04-23-2018, 09:33 PM   #3
My 2015 Cummings doesn't do that good. Pulling the fiver really sucks it down!
2015 Flagstaff 831RBLSS
2015 Ram 2500 6.7 Cummings Crew
2014 Lowe Stinger 175
2013 FJR1300
Hthunder is offline   Reply With Quote
Old 04-23-2018, 10:30 PM   #4
Per a MB tech. If you don't fill the DEF tank to the top the system does not reset and you may find yourself in countdown mode even with plenty of DEF in the tank.
Beachsailor is offline   Reply With Quote
Old 04-24-2018, 07:49 AM   #5
AudiDudi's Avatar
Interesting. When I brought up the DEF gauge after adding, it sat at 3 bars for maybe 15 seconds (long enough for me to think maybe I needed to run the engine or drive it a bit), then it slowly added 1 bar at a time til it reached 8 bars.
Mike and JoAnne
Old 04-26-2018, 08:03 AM   #6
Because of the problems involved we top off the DEF after every 60-70 gallons (3 fuel stops) .
Seems the stuff dries out and may take a long time to tell the computer all is well.
FFred is offline   Reply With Quote
Old 04-26-2018, 10:58 AM   #7
Rkloud9's Avatar
I have found that 2500 miles is when a 2.5 gallon container will fill it to the top. We have a 2016 chassis, and I believe a dash indicator will let you know when it is down to about 40%. I have only seen it once, on our first trip, and I had to check the manual to figure out what it meant. As others have stated, keeping it above half is a good practice, as a white powder precipitates when it dries, and that stuff can mess up the tank sensors. Also, be scrupulously clean in the filling process, and if any is spilled, rinse it off with water, as it is acidic.
Happy travels!
Bob & Cynthia
2017 SunSeeker MBS 2400W
Rkloud9 is offline   Reply With Quote
Old 04-26-2018, 11:06 AM   #8
Prime Member
The DEF sensor in my Silverado won't register a low level until only 20% remains.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 04-26-2018, 02:13 PM   #9
flocktothewall's Avatar
We seem to fill our def up every 2000 miles or so. Our MB tech said itís a 5 gallon tank but light comes on when 2.25 gallons are needed. We have a 2014 chassis no indicator on our model.
flocktothewall is offline   Reply With Quote
Old 04-28-2018, 10:57 AM   #10
AudiDudi's Avatar
One my 2016, if you hold the maintenance button down within 2 seconds of turning on the ignition, it will show miles left to the next oil change and if you push it again (maybe twice more), it shows the DEF level similiar to the fuel gauge.
Mike and JoAnne
