Old 07-31-2016, 01:33 PM   #11
waiter21's Avatar
Some codes (most) will auto clear the Check engine light but remain in memory for some time. Then given enough start cycles, they will clear out of memory.
i.e. the famous Evap slow leak P0422 will clear itself if the OBC successfully completes the entire Evap canister purge cycle and doesn't detect a leak. This code is usually set when you forget to put the gas cap on.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-02-2016, 01:45 PM   #12
[QUOTE=ilmor;1276049]The issue is that their software includes an additional feature which, when the consumer tries to repair and or take care of things himself, FORCES the consumer to use Mercedes and only Mercedes service (and resultant extreme costs).
We've had work done on our Mercedes Sprinter at two different Mercedes dealerships - one in Scottsdale, AZ, and one in Sioux Falls, SD, and both did so with reasonable cost to us. The fees for the work done didn't seem any different than having work done locally at our Jeep and Chevrolet dealerships (for our other vehicles.)
Larry, Paula & Bailey the Adorable Red Toy Poodle
aspengirl is offline   Reply With Quote
Old 08-05-2016, 02:05 PM   #13
RailwayRog
What year sprinter is the OP referencing?
2010 Coachmen Prism M240
(2008 Freightliner 3500 chassis)
RailwayRog is offline   Reply With Quote
Old 08-05-2016, 05:55 PM   #14
It's a 2015 Solera on a 2014 MB 3500.
nusslejj is offline   Reply With Quote
Old 08-05-2016, 10:27 PM   #15
RailwayRog
I've got the older version, doesn't seem to have that problem since I've clear codes a lot.
Old 08-07-2016, 12:32 PM   #16
The OP posted in the MB forum to discuss MB Sprinter issue. It is best to stay vehicle specific in posting, based on your MB knowledge in the area of the OP topic. Otherwise, the thread becomes poluted with mine (ford chassis) does this. Not constructive to the OP's original intent. In learning, your post on the "mode 6" was very informative. I assume all OBD II computers have a mode six retention, although I do not know for sure. The problem occurs when certain manufacturers, try to make some facets of the diagnostics proprietary, just not sure in this case however. Just sayin'
