Old 04-29-2019, 04:24 PM   #1
Does the alternator charge the house batteries in a 2016 Coachmen Prism 24G?
How can you test that the alternator charges the house batteries?
Vegabonds is offline   Reply With Quote
Old 04-29-2019, 05:31 PM   #2
AudiDudi's Avatar
Yes, it does. When the engine is turned on, you should here a click of a relay, that enables house batteries to charge. Be sure that the battery control switch is in the on position. Use a volt meter to check the voltage on the batteries - when charging they should read 13.2+ volts. Be sure you are disconnected from shore power when checking.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 06-28-2019, 01:04 PM   #3
Ragtimeplayer's Avatar
House battery not charging.
2016 MBS 2401R. 7k miles into our trip and the house batteries under entry step seemed to not be charging. This morning generator barely started allowing us to retract slide. Chassis battery seems fine with no codes. House battery indicator on panel showing 1 red light (low). Generator wonít start now. Just drove 2.5 hours and thought driving would charge them up. Stopped for fuel and they are still low and generator wonít start. It has not been shore power for 2 weeks and batteries were slowly going down while it sat in driveway, figured this stretch would get it charged up. Is there a fuse or connection that could have rattled loose on some very rough roads? Any thoughts. Will drive another couple hours and check this forum for things to check. Thanks!
2017 Forester MBS 2401R
2011 F350 PSD w Torklifts/Bags and H&S DPF delete
Ragtimeplayer is offline   Reply With Quote
Old 07-01-2019, 08:12 AM   #4
House batteries are charged by the converter when on generator or shore power. They are charged by the MB alternator when voltage drops low enough and the BCC (Battery control center) closes the relay for them to charge. The same BCC will also charge the chassis battery from the converter if the chassis battery voltage drops below the programmed limit.
If the chassis batteries won't charge either with shore power, generator or engine alternator, you might have a wiring issue. I found really poor crimps from the factory at the battery cables - so check there to start. You could also have two fried batteries. I replaced mine with Group 31 AGM batteries several years ago.
KatanaPilot is offline   Reply With Quote
Old 07-01-2019, 08:50 AM   #5
bubbles's Avatar
I think the coach batteries have priority when on shore/genny power and chassis battery has priority when alternator is supplying charging. In other words, the chassis battery charging (on shore/genny power) will not take place till the coach batteries are at a preset level. Conversely, coach battery charging (from alternator) will not take place till chassis battery is at a preset level. This is how a battery control center typically operates. The same solenoid (relay) is utilized for both charging scenarios and if installed, the emergency start function as well. JMO.
batteries, coachmen
