Dometic A/C & heat pump
Second night out on our 2017 2400W Sunseeker, which we purchased in October. First night, heat pump kept us toasty in 55 degree weather and everything was fine. Second night, after driving about 200 miles, we turned the thermostat to heat pump in 55 degree weather. Pump came on, heat came up, then pump went to either just fan or cooling (not sure which). Now, every time the thermostat asks for heat, including if I have it set for furnace, the heat pump comes on and won't shut off. I have to trip the breaker to get it to shut off and let the furnace do its thing.
I'm thinking the problem is some sort of limit switch in the heat pump that will require warranty attention, but I'm looking for any other suggestions that will avoid us having to change our schedule.
Thanks!
