Originally Posted by Tall Guy
1. In high temperatures (100+ in Utah this month), the Dometic heat pump will sometimes cycle on and off several times within 30 seconds to a minute. Both the compressor and fan cycle. This seems to happen as the inside temperature gets close to the thermostat setting. Is this common
I think this was discussed in a recent thread. If you've got the fan set on "Auto" (at the thermostat) then the whole thing more or less goes off for a few seconds, then goes back on, when the fan switches speeds. You might try setting the fan to a single speed to see if the behavior goes away.
2. We noticed that the two a/c vents in the middle of the cabin, just in front of the a/c unit, have small wooden blocks (app. 2x2x1) we can see in the ductwork behind the vent openings. Neither is anchored or attached to anything; they are just sitting in the duct. My thinking is they were probably used as a jig or alignment aid during assembly, but I'm not sure. So, any thoughts on what they are or how to remove them? I'm not sure if the vent covers are supposed to snap out in some way.
I'm not exactly sure which vent cover you're talking about, but if it's like mine, it's the main cover in the center of the ceiling and has vents for both air from the A/C and air returning to the A/C. The return air cover (toward the front of the RV) is removable to allow cleaning of the dust filter. The A/C outlet vents (which can slide either open or closed) are builtin to the main cover. I would take the return air cover off and look around inside to see if there's an obvious way to remove the whole cover.
As far as the blocks of wood, I'd guess that they're just construction debris - you'll find stuff like that pretty much anywhere that is even slightly hidden - under cabinets, behind drawers, in walls, etc.
Dave
