Old 03-08-2016, 09:28 AM   #11
RedLdr1's Avatar
I definitely down shift going up steep inclines as the transmission is a bit too optimistic on how long to stay in top gear. When descending I downshift if it feels like I need to or it is a steep grade. If there is a sign warning trucks about a grade and to down shift I generally follow the advise...
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 03-08-2016, 08:20 PM   #12
Originally Posted by Mikegjax View Post
Shift up or down depending grade. Recommended in operators manual.
Absolutely X 2
Old 03-09-2016, 12:28 AM   #13
MNtraveler's Avatar
Seems the cruise control will downshift for you to control speed down hills. But I haven't tried it on any large hills or mountains yet.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 03-10-2016, 01:01 AM   #14
MNtraveler's Avatar
As the AT will downshift when it needs for the most part, one of the main reasons for downshifting manually when going up hills is to stop gear "hunting" whereby the AT downshifts, brings you back to speed then upshifts, then you slow down with loss of engine power and it downshifts, and on and on. In addition to being quite annoying, this can overheat and damage the AT. Downshifting manually puts it where it needs to be and keeps it there for the duration. You then set and control the speed and keep it right there.
2016 Forester 2401R
Old 03-10-2016, 01:10 AM   #15
MNtraveler's Avatar
A very good article on this topic:
https://www.fmca.com/motorhome/motor...-the-work.html
2016 Forester 2401R
Old 03-10-2016, 10:35 AM   #16
bob dirt's Avatar
Good article. Always scared of running the R's that high but it makes sense
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 03-15-2016, 09:25 PM   #17
MNtraveler's Avatar
Anyone have an opinion on how many revs are too many for the MBS engine?
(Need I even ask if anyone has an opinion?!)
2016 Forester 2401R
Old 03-15-2016, 09:59 PM   #18
Originally Posted by namusmc View Post
Also, engine braking prolongs the life of brake pads and rotors.
As long as it doesn't over rev the engine. Brake pads & rotors are cheaper than rods, brgs & crankshafts. I limit my old Chevy to 3600 rpm up hill and down hill I use the brakes intermittently.
Old 03-16-2016, 03:39 PM   #19
Mikegjax's Avatar
I remember reading somewhere (don't ask where) that the computer will not let you over rev the engine.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-16-2016, 03:55 PM   #20
MNtraveler's Avatar
Interesting. I can see how it would do it uphill (throttle limit), but now sure how it would do it downhill when it's driven by gravity - unless it disconnects the tranny. Well, maybe it just upshifts (duh!) and you are on your own with the brakes at that point until you bring it back down to a reasonable speed (which is what one should be doing anyway).
2016 Forester 2401R
