Old 05-20-2016, 05:47 PM   #31
flocktothewall's Avatar
Originally Posted by Rich.M View Post
Group 31 AGM will fit without modification. Just watch the dimensions of the brand you select. Duracell grp 31 AGM at Sams fit my unit. Ista is using the grp 31 agm in the same battery box. Good luck and happy camping.
Just picked up the same batteries from Sams Club today. Got a new 12v plug coming in the mail from Jenson.
flocktothewall is offline   Reply With Quote
Old 05-20-2016, 06:27 PM   #32
Rich.M's Avatar
It's a tight squeeze , need to slide the first battery in all the way over and bring the loosened strap around the 1st corner before second battery in. They do fit, but I haven't tried to get them out.
2015 Solera 24r
Rich.M is offline   Reply With Quote
Old 05-20-2016, 09:06 PM   #33
Electrical/12v issues.
Originally Posted by KatanaPilot View Post
One of the reasons my batteries died is because of the poor crimps performed at the factory on one of the battery cables. So once you have all the batteries out of the battery box, give a tug on the terminal ends to make sure they are attached properly.
Name:   ImageUploadedByForest River Forums1463792780.946212.jpg
Wouldn't ya know it? I barely pull it and it came right out.
Old 05-22-2016, 05:57 AM   #34
Want to see my shocked face?
Originally Posted by flocktothewall View Post
Attachment 108487
Good to see process control is alive and well at FR.
KatanaPilot is online now   Reply With Quote
Old 10-01-2016, 05:23 PM   #35
UPDATE: Bought new group 27 batteries after this thread. All worked well. Now after a few months the batteries will only show 12.48 volts after being plugged into shore power for weeks.
The converter WFCO 2855 shows 13.52 volts to the battery but yet they won't get above 12.48.
I called my dealers tech support like and the RV tech said don't worry about it that is an adequate charge.
Any Input?
Old 10-01-2016, 06:02 PM   #36
MNtraveler's Avatar
12.48V is roughly 90% charged. The >13V charging current is to push the charge in. The battery will never go to that level. See chart.
Name:	ImageUploadedByForest River Forums1475359305.059022.jpg
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 29; RV to date: 32
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 10-01-2016, 06:07 PM   #37
Flybob's Avatar
A fully charged battery ( after some rest) is shown below.
Approximate state-of-charge \Average Open circuit voltage
specific gravity
100% 1.265 12.65
75% 1.225 12.45
50% 1.19 12.24
25% 1.155 12.06
0% 1.12 11.89
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-02-2016, 11:38 AM   #38
I just want to say thanks for all the help and guidance. Im amazed at how much knowledge it takes to own an RV. My head is still kind of spinning.
So true! I have friends regularly ask if they can rent it and I tell them it would take a two day class and then I would have to provide 24hr phone support. Some things we learn by breaking them first!
2016 Sunseeker W MBS
kysunseekermbs is online now   Reply With Quote
Old 10-02-2016, 08:40 PM   #39
Mikegjax's Avatar
Just say NO!!!!
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-03-2016, 10:39 AM   #40
My concern is that the batteries no longer reach a voltage above 12.48 volts. Even after being charged for weeks.
So I'm effectively only getting 80% out of them.
The question I ask is where or what is causing that? Converter is charging why wouldn't batteries charge? I have a hydrometer and no cells are bad... defective battery or something else?
electric, electrical
