Old 05-05-2019, 08:28 PM   #1
raptor's Avatar
Electrical question on MBS 2401R
Hi,
I'm having real bad static problem on all my radio. Do you think by looking at that pictures, those cables in rack are ground cables? If they are then they are not attached to chassis just to the cabinet.
ID:	203826   Click image for larger version
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 05-05-2019, 08:39 PM   #2
That appears to be a ground buss. It is grounded by the heavy white wire going into the distribution panel. It is simply mounted to the cabinet hold it in place, not to ground to the RV chassis. Most likely the other heavy cable goes to the chassis, grounding it to the distribution panel.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 05-05-2019, 08:57 PM   #3
raptor's Avatar
Thanks. Now I need to look some where else that cause radio static.
raptor
America is great
Old 05-06-2019, 06:07 AM   #4
Sorry, can't help you much there. Do check that all screws are tight on the ground buss.
Old 05-06-2019, 07:31 AM   #5
I would say bad ignition wires cause radio static but that would be laughable given that the MBS is a diesel
Possibly poor grounding of the radio antenna on the roof?
KatanaPilot is offline   Reply With Quote
Old 05-06-2019, 07:54 AM   #6
Inexpensive LED lights often give off RF interference.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 05-06-2019, 09:40 AM   #7
Mikegjax's Avatar
Hi,
You might need to add a ground loop filter similar to this. https://www.crutchfield.com/S-iQk3MJ...IaAsZ0EALw_wcB
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-06-2019, 11:39 AM   #8
madatme's Avatar
I work at a car dealer and had a customer complaining of his radio would shut off briefly when he mashed the brakes, sure enough it did it and I found aftermarket led brake light bulbs installed, replaced with correct bulbs and problem resolved, remove your bulbs if you replaced them, interference
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
madatme is offline   Reply With Quote
Old 05-06-2019, 01:34 PM   #9
cavie's Avatar
me thinks the red cable does not belong there,
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-06-2019, 03:50 PM   #10
Mikegjax's Avatar
I ment to say " ground loop isolater
2014 Solera 24R
USN Retired
electric, electrical
